Comm ports on Pc386
Angelo Fraietta angelo at hunterlink.net.au
Tue Jul 3 05:52:34 UTC 2001
Thank you for the help you have provided so far. I eventually got the program
to build by adding
#define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
When I attempt to run the program, I get the message that /dev/ttsy1 & 2 are
initialised, however, I get the messages
RTEMS: creating task sh1 in shell_init() (status: request not satisfied)
I get a similar message for all three tasks.  Additionally, I spawned a task
like the previous attempt, using  fopen ("/dev/ttys1"), however, this fails
also.
The code in its entirety is as follows:
#define TEST_INIT
#include <bsp.h>
void test_main( void );
rtems_task Init(
  rtems_task_argument ignored
  test_main();
/* configuration information */
#include <tty_drv.h>
#include <console.h>
#include <clockdrv.h>
#include <timerdrv.h>
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_MAXIMUM_TASKS             6
rtems_driver_address_table Device_drivers[] = {
        CONSOLE_DRIVER_TABLE_ENTRY,
        TTY1_DRIVER_TABLE_ENTRY,
        TTY2_DRIVER_TABLE_ENTRY,
        CLOCK_DRIVER_TABLE_ENTRY,
        {NULL,NULL,NULL,NULL,NULL,NULL},
/*#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER*/
#define CONFIGURE_INIT
#include <confdefs.h>
rtems_id   Task_id;
rtems_name Task_name;
rtems_task Test_task( rtems_task_argument unused);
void test_main()
  rtems_status_code status;
  Task_name = rtems_build_name( 'T', 'A', '1', ' ' );
  status = rtems_task_create(
    Task_name, 1, RTEMS_MINIMUM_STACK_SIZE * 2, RTEMS_DEFAULT_MODES,
    RTEMS_DEFAULT_ATTRIBUTES, &Task_id
  status = rtems_task_start( Task_id, Test_task, 1 );
shell_init("sh1",16384,100,"/dev/ttyS1"  ,B9600|CS8,TRUE);
shell_init("sh2",16384,100,"/dev/ttyS2"  ,B9600|CS8,TRUE);
shell_init("shc",16384,100,"/dev/console",B9600|CS8,TRUE);
const char* tty_ports [] =
 "/dev/ttyS1",
 "/dev/ttyS2"
 FILE* fp = fopen (tty_ports [0], "r+");
 if (!fp)
   printf ("Unable to open %s", tty_ports [0]);
 else
   while (1)
     if (!fputc('t', fp))
       printf ("unable to write to port");
"Fernando RUIZ CASAS (E-mail)" wrote:
> Hi
> If you want to use shell_init without tpc/ip enabled I can send to you
> the patch already submitted to Joel.(05/26/01)
> I have not made none modification in the pc386 BSP code to enable
> the ports. Only this code has been used.
> In shell_init only a make raw mode TERMIOS is done
> (How the linux man page says)
> None error is showed in the compilation of pc386(pc686) bsp.
> Browse in the sources and ask directely to Eric, Rosimildo & more about the
> use of this. (The authors of little patchs...)
> I have use this ports like a linux device using only TERMIOS programming.
> And this works successfully.
> Your code seems correct. I Can try it.
> Fernando RUIZ CASAS
> home:correo at fernando-ruiz.com
> work:fernando.ruiz at ctv.es
> > -----Mensaje original-----
> > De: Angelo Fraietta [mailto:angelo at hunterlink.net.au]
> > Enviado el: lunes, 02 de julio de 2001 3:38
> > Para: correo at fernando-ruiz.com
> > CC: Rtems-Users (E-mail)
> > Asunto: Re: Comm ports on Pc386
> > I am using the previous snapshot as  do not have networking
> > enabled. I am
> > trying to open the commport and write some chars (for now).
> > If I just try to
> > open the port without the code you provided, the file does
> > not open. I assume
> > it is because the port has to be configured with the code you
> > provided.
> > However, trying to compile this below, I get a heap of parse errors in
> > ttr_drv.h.
> > Is this because of the snapshot or am I doing something wrong here?
> > #define CONFIGURE_MAXIMUM_TASKS             1
> > rtems_id   Task_id;
> >  "/dev/ttyS1",
> >  "/dev/ttyS2"
> >  if (!fp)
> >  else
> >    while (1)
> > Init()
> >   status = rtems_task_start( &Task_id, Test_task, 1 );
> > > > Enviado el: jueves, 28 de junio de 2001 3:52
> > > > Para: rtems-users
> > > > Asunto: Comm ports on Pc386
> > > > Does anyone have an example of using the comm ports on a
> > PC386 build?
> > > Adding this like rtems device configuration you have
> > > THREE termios ports in your PC.
> > > /dev/console
> > > /dev/ttyS1
> > > /dev/ttyS2
> > > How to manage this ports with TERMIOS?
> > > See the /rtems/c/src/tests/libtests/termios directory.
> > > A complete program to drive a termios device.
> > > (My first source to understand it. Thanks Eric Norum)
> > > Enjoy it.
> > > Are you using the last snapshot (20010525)?
> > > With this you can open remote consoles in every port termios.
> > > /* TASK NAME,STACK SIZE, TASK PRIO, DEV_NAME, BAUDS & LINE
> > SETT.,FOREVER*/
> > > #include <shell.h>
> > > Init() {
> > > shell_init("sh1",16384,100,"/dev/ttyS1"  ,B38400|CS8,TRUE);
> > > shell_init("sh2",16384,100,"/dev/ttyS2"  ,B38400|CS8,TRUE);
> > > shell_init("shc",16384,100,"/dev/console",B38400|CS8,TRUE);
> > > Three users accessing at same time at the PC but with RTEMS rtos.
> > > A new task for evevy user.
> > > Fernando RUIZ CASAS
> > > home: correo at fernando-ruiz.com
> > > work: fernando.ruiz at ctv.es
> > > > Angelo Fraietta
> > > > PO Box 859
> > > > Hamilton NSW 2303
> > > > Home Page
> > > > http://users.hunterlink.net.au/~maaaf/
> > > > There are those who seek knowledge for the sake of
> > knowledge - that is
> > > > CURIOSITY
> > > > There are those who seek knowledge to be known by others - that is
> > > > VANITY
> > > > There are those who seek knowledge in order to serve -
> > that is LOVE
> > > >     Bernard of Clairvaux (1090 - 1153)
> > Angelo Fraietta
> > PO Box 859
> > Hamilton NSW 2303
> > Home Page
> > There are those who seek knowledge for the sake of knowledge - that is
> > CURIOSITY
> > that is VANITY
> > There are those who seek knowledge in order to serve - that is LOVE
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
URL: <http://lists.rtems.org/pipermail/users/attachments/20010703/366b3a21/attachment-0001.html>
