Comm ports on Pc386
Angelo Fraietta
angelo at hunterlink.net.au
Tue Jul 3 07:28:17 UTC 2001
I appears that the call to fopen should somehow make its way to
tty1_open. I do not believe that this is happening as I am not getting
the fail message from that call. Tomorrow I will have a closer
investigation and maybe place some code in there to display whether it
is getting there. Could it be that the call to fopen requires some other
configuration in order to map the device driver to the filename?
Angelo Fraietta wrote:
> Thank you for the help you have provided so far. I eventually got the
> program to build by adding
> #define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
> When I attempt to run the program, I get the message that /dev/ttsy1 &
> 2 are initialised, however, I get the messages
> RTEMS: creating task sh1 in shell_init() (status: request not
> satisfied)
> I get a similar message for all three tasks. Additionally, I spawned
> a task like the previous attempt, using fopen ("/dev/ttys1"),
> however, this fails also.
> The code in its entirety is as follows:
> #define TEST_INIT
> #include <bsp.h>
> void test_main( void );
> rtems_task Init(
> rtems_task_argument ignored
> test_main();
> /* configuration information */
> #include <rtems.h>
> #include <tty_drv.h>
> #include <console.h>
> #include <clockdrv.h>
> #include <timerdrv.h>
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_MAXIMUM_TASKS 6
> rtems_driver_address_table Device_drivers[] = {
> CONSOLE_DRIVER_TABLE_ENTRY,
> TTY1_DRIVER_TABLE_ENTRY,
> TTY2_DRIVER_TABLE_ENTRY,
> CLOCK_DRIVER_TABLE_ENTRY,
> {NULL,NULL,NULL,NULL,NULL,NULL},
> /*#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER*/
> #define CONFIGURE_INIT
> #include <confdefs.h>
> #include <stdio.h>
> rtems_id Task_id;
> rtems_name Task_name;
> rtems_task Test_task( rtems_task_argument unused);
> void test_main()
> rtems_status_code status;
> Task_name = rtems_build_name( 'T', 'A', '1', ' ' );
> status = rtems_task_create(
> Task_name, 1, RTEMS_MINIMUM_STACK_SIZE * 2, RTEMS_DEFAULT_MODES,
> RTEMS_DEFAULT_ATTRIBUTES, &Task_id
> status = rtems_task_start( Task_id, Test_task, 1 );
> shell_init("sh1",16384,100,"/dev/ttyS1" ,B9600|CS8,TRUE);
> shell_init("sh2",16384,100,"/dev/ttyS2" ,B9600|CS8,TRUE);
> shell_init("shc",16384,100,"/dev/console",B9600|CS8,TRUE);
> const char* tty_ports [] =
> "/dev/ttyS1",
> "/dev/ttyS2"
> FILE* fp = fopen (tty_ports [0], "r+");
> if (!fp)
> printf ("Unable to open %s", tty_ports [0]);
> else
> while (1)
> if (!fputc('t', fp))
> printf ("unable to write to port");
> "Fernando RUIZ CASAS (E-mail)" wrote:
>> Hi
>> If you want to use shell_init without tpc/ip enabled I can send to
>> you
>> the patch already submitted to Joel.(05/26/01)
>> I have not made none modification in the pc386 BSP code to enable
>> the ports. Only this code has been used.
>> In shell_init only a make raw mode TERMIOS is done
>> (How the linux man page says)
>> None error is showed in the compilation of pc386(pc686) bsp.
>> Browse in the sources and ask directely to Eric, Rosimildo & more
>> about the
>> use of this. (The authors of little patchs...)
>> I have use this ports like a linux device using only TERMIOS
>> programming.
>> And this works successfully.
>> Your code seems correct. I Can try it.
>> Fernando RUIZ CASAS
>> home:correo at fernando-ruiz.com
>> work:fernando.ruiz at ctv.es
>> > -----Mensaje original-----
>> > De: Angelo Fraietta [mailto:angelo at hunterlink.net.au]
>> > Enviado el: lunes, 02 de julio de 2001 3:38
>> > Para: correo at fernando-ruiz.com
>> > CC: Rtems-Users (E-mail)
>> > Asunto: Re: Comm ports on Pc386
>> > I am using the previous snapshot as do not have networking
>> > enabled. I am
>> > trying to open the commport and write some chars (for now).
>> > If I just try to
>> > open the port without the code you provided, the file does
>> > not open. I assume
>> > it is because the port has to be configured with the code you
>> > provided.
>> > However, trying to compile this below, I get a heap of parse
>> errors in
>> > ttr_drv.h.
>> > Is this because of the snapshot or am I doing something wrong
>> here?
>> > #define CONFIGURE_MAXIMUM_TASKS 1
>> > rtems_id Task_id;
>> > "/dev/ttyS1",
>> > "/dev/ttyS2"
>> > if (!fp)
>> > else
>> > while (1)
>> > Init()
>> > status = rtems_task_start( &Task_id, Test_task, 1 );
>> > > > Enviado el: jueves, 28 de junio de 2001 3:52
>> > > > Para: rtems-users
>> > > > Asunto: Comm ports on Pc386
>> > > > Does anyone have an example of using the comm ports on a
>> > PC386 build?
>> > > Adding this like rtems device configuration you have
>> > > THREE termios ports in your PC.
>> > > /dev/console
>> > > /dev/ttyS1
>> > > /dev/ttyS2
>> > > How to manage this ports with TERMIOS?
>> > > See the /rtems/c/src/tests/libtests/termios directory.
>> > > A complete program to drive a termios device.
>> > > (My first source to understand it. Thanks Eric Norum)
>> > > Enjoy it.
>> > > Are you using the last snapshot (20010525)?
>> > > With this you can open remote consoles in every port termios.
>> > > /* TASK NAME,STACK SIZE, TASK PRIO, DEV_NAME, BAUDS & LINE
>> > SETT.,FOREVER*/
>> > > #include <shell.h>
>> > > Init() {
>> > > shell_init("sh1",16384,100,"/dev/ttyS1" ,B38400|CS8,TRUE);
>> > > shell_init("sh2",16384,100,"/dev/ttyS2" ,B38400|CS8,TRUE);
>> > > shell_init("shc",16384,100,"/dev/console",B38400|CS8,TRUE);
>> > > Three users accessing at same time at the PC but with RTEMS
>> rtos.
>> > > A new task for evevy user.
>> > > Fernando RUIZ CASAS
>> > > home: correo at fernando-ruiz.com
>> > > work: fernando.ruiz at ctv.es
>> > > > Angelo Fraietta
>> > > > PO Box 859
>> > > > Hamilton NSW 2303
>> > > > Home Page
>> > > > http://users.hunterlink.net.au/~maaaf/
>> > > > There are those who seek knowledge for the sake of
>> > knowledge - that is
>> > > > CURIOSITY
>> > > > There are those who seek knowledge to be known by others -
>> that is
>> > > > VANITY
>> > > > There are those who seek knowledge in order to serve -
>> > that is LOVE
>> > > > Bernard of Clairvaux (1090 - 1153)
>> > Angelo Fraietta
>> > PO Box 859
>> > Hamilton NSW 2303
>> > Home Page
>> > There are those who seek knowledge for the sake of knowledge -
>> that is
>> > CURIOSITY
>> > that is VANITY
>> > There are those who seek knowledge in order to serve - that is
>> LOVE
> Angelo Fraietta
> PO Box 859
> Hamilton NSW 2303
> Home Page
> There are those who seek knowledge for the sake of knowledge - that is
> CURIOSITY
> There are those who seek knowledge to be known by others - that is
> VANITY
> There are those who seek knowledge in order to serve - that is LOVE
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
CURIOSITY
VANITY
URL: <http://lists.rtems.org/pipermail/users/attachments/20010703/7996be16/attachment-0001.html>
