Problems with starting new BSP
Radzislaw Galler rgaller at ET.PUT.Poznan.PL
Tue Jul 3 15:58:50 UTC 2001
Hi,
Recently I built a board with SH2 processor (SH7044). I also developed
application using Hitachi EVB7045 and gensh2 BSP. Now it's time to port it to
my board. Idecided to make my own BSP, because it was necessary to change
linkcmds and start routine (my board differs from EVB in memory layout and
size).
According to Fernando Ruiz Casas guide I created my BSP and had no problem
with adding it to RTEMS tree and build it. But the same application that runs
with no problems on EVB doesn't want to run my board. After a looooong
investigation I found out that disabling clock driver would help for a while:
the application is able to start all tasks and switch context to every one...
but only once. After that all tasks become waiting on timeout.
I found it out thanks to RTEMS extension I made. The procedure connected to
context switch just prints heir and current tasks names and states.
Also if I enable clock driver and disable interrupts soon enough I am able to
see some debugging info on terminal. But reenabling interrupts casues some
infinite loop somewhere. If I leave interrupts enabled the system hangs after
printing first three letters on terminal.
On EVB I am able to debug application or even RTEMS itself but not on my
board. After the failure even NMI doesn't work.
Because the same application (even with this extension) works without any
problem on EVB I believe the bug is somewhere in my BSP initialization. Here
is an information I get on terminal from my board:
-------------------Start------------------------
VBR: 0x2015c0 vectab: 0x2015c0 _ISR_Vector_table: 0x23fbc4
vectab[88]: 0x59d4 __ISR_Handler: 0x54d0
_ISR_Vector_table[88]: 0x2f60 Clock_isr: 0x2f60
_mtua0_isp: 0x59d4
WorkSpaceStart = 0x207d6c; WorkSpace size = 00038294 (230036)
Malloc stats
  avail:20k  allocated:3k (19%) max:3k (19%) lifetime:0k freed:3k
  Call counts:   malloc:5   free:0   realloc:0   calloc:10
Install monitor success
ALRM task creation success
ALRM task start success
Malloc stats
  avail:20k  allocated:5k (29%) max:5k (29%) lifetime:0k freed:5k
  Call counts:   malloc:7   free:0   realloc:0   calloc:12
=========== Configuration registers ============
BSC_BCR1   =  200F
BSC_BCR2   =  FFFF
BSC_WCR1   =  FF33
BSC_WCR2   =  000F
BSC_DCR    =  0000
BSC_RTCSR  =  0000
BSC_RTCNT  =  0000
BSC_RTCOR  =  0000
PFC_PACRL1 =  1555
PFC_PACRL2 =  AD45
PFC_PBCR1  =  0000
PFC_PBCR2  =  2005
PFC_PCCR   =  FFFF
PFC_PDCRL  =  FFFF
PFC_IFCR   =  0000
PFC_PECR1  =  0000
PFC_PECR2  =  0000
PFC_PEIOR  =  00FF
[Here the application hangs]
And here is output from the EVB (the same untouched application - only BSP
differs):
VBR: 0x442000 vectab: 0x442000 _ISR_Vector_table: 0x47fbc4
vectab[88]: 0x4495a4 __ISR_Handler: 0x4490a0
_ISR_Vector_table[88]: 0x446b30 Clock_isr: 0x446b30
_mtua0_isp: 0x4495a4
WorkSpaceStart = 0x46ca8c; WorkSpace size = 00013574 (79220)
Malloc stats
Malloc stats
BSC_BCR1   =  2020
BSC_BCR2   =  F3DD
BSC_WCR1   =  FF3F
BSC_WCR2   =  000F
BSC_DCR    =  0000
BSC_RTCSR  =  0000
BSC_RTCNT  =  0000
BSC_RTCOR  =  0000
PFC_PACRL1 =  1550
PFC_PACRL2 =  0145
PFC_PBCR1  =  0000
PFC_PBCR2  =  2005
PFC_PCCR   =  FFFF
PFC_PDCRL  =  FFFF
PFC_IFCR   =  0000
PFC_PECR1  =  0000
PFC_PECR2  =  0000
PFC_PEIOR  =  0020
*<<*s:47D0C8 *p: st*: 4 n:RM*ON st: 0>*>
Mon*itor read*y, press *enter to* login.
<<s:47*BC1C p:RM*ON st: 0 *n:ALRM s*t: 0>>
<*<s:479FD*4 p:ALRM *st: 8 n:R*MON st: *0>>
<<s:*47BC1C p*:RMON st:* 0 n:IDLE* st: 0>>*
<<s:47E*1A8 p:ID*LE st: 0 *n:RMON st*: 0>>
<*<s:47BC1C* p:RMON *st: 0 n:I*DLE st: 0*>>
*<s:*47E1A8 p:*IDLE st:* 0 n:RMON* st: 0>>
 <<s:47B*C1C p:RMO*N st: 0 *n:IDLE st*: 0>>
<<*s:47E1A8* p:IDLE s*t: 0 n:R*MON st: 0*>>
*<s:4*7BC1C p:*RMON st: *0 n:IDLE* st: 0>>
 <<s:47E1*A8 p:IDL*E st: 0 n*:RMON st*: 0>>
<<*s:47BC1C *p:RMON s*t: 0 n:ID*LE st: 0*>>
*<s:4*7E1A8 p:I*DLE st: *0 n:RMON *st: 0>>
 <<s:47BC*1C p:RMON* st: 0 n*:IDLE st:* 0>>
<<*s:47E1A8 *p:IDLE st*: 0 n:RM*ON st: 0>*>
<<s:4*7BC1C p:R*MON st: 0* n:IDLE *st: 0>>
*<<s:47E1*A8 p:IDLE* st: 0 n:*RMON st:* 0>>
<<s*:47BC1C *p:RMON st*: 0 n:IDL*E st: 0>*>
<<s:47*E1A8 p:I*DLE st: 0* n:RMON s*t: 0>>
*<<s:47BC1*C p:RMON* st: 0 n:*IDLE st: *0>>
<<s*:47E1A8 p*:IDLE st*: 0 n:RMO*N st: 0>>*
<<s:47*BC1C p:RM*ON st: 0* n:IDLE s*t: 0>>
<*<s:47E1A*8 p:IDLE *st: 0 n:*RMON st: *0>>
<<s:*47BC1C p*:RMON st:* 0 n:IDL*E st: 0>>*
<<s:47E*1A8 p:ID*LE st: 0 *n:RMON s*t: 0>>
<*<s:47BC1C* p:RMON *st: 0 n:A*LRM st: *0>>
*<s:*479FD4 p:*ALRM st:* 8 n:RMON* st: 0>>
[snip]
The asterisk (*) indicates that clock ISR has reached some countdown (see
code in ckinit.c)
Attached you will find files that have some meaning in this case. I will
appreciate any clue.
Thanks
Radzislaw Galler
rgaller at et.put.poznan.pl
Type: application/x-gzip
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20010703/097b494d/attachment-0002.bin>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20010703/097b494d/attachment-0003.bin>
