Patch To avoid tcp/ip enabled in last snapshot (25052001)
Angelo Fraietta angelo at hunterlink.net.au
Tue Jul 3 20:46:52 UTC 2001
The pc686 just built for me. I'll do some more tests to find out what is
going on at my end.
"Fernando RUIZ CASAS (E-mail)" wrote:
> Hi Angelo.
>  Yesterday. I have could rebuild in cygwin (In Linux no problem) all the
>  tool chain including the last snapshot and build a new BSP pc686
>  without problems (With the patch applied).
>  What kind of problems have you?
>  Rebuilding the BSP with
>   make all install 2>errorfile
>  you can capture the errors.
> Fernando RUIZ CASAS
> home:correo at fernando-ruiz.com
> work:fernando.ruiz at ctv.es
> > -----Mensaje original-----
> > De: Angelo Fraietta [mailto:angelo at hunterlink.net.au]
> > Enviado el: martes, 03 de julio de 2001 7:55
> > Para: fernando.ruiz at ctv.es
> > Asunto: Re: Patch To avoid tcp/ip enabled in last snapshot (25052001)
> > I applied the patch, however, it appears that only the pc386
> > is successfully being built. I get
> > configure errors when I try to build pc386dx and pc686.
> > > Hi rtems-users.
> > > In order to build the last snapshot with tcp/ip disabled
> > here a patch
> > > moving the telnetd and pty to libnetworking directory.
> > > This patch is already submitted to Joel.
> > > But while the new snapshot arrives,a solution is here.
> > > Sorry for the inconvenience.
> > > Fernando RUIZ CASAS
> > > De: Correo Fernando-ruiz (E-mail) [mailto:correo at fernando-ruiz.com]
> > > Enviado el: lunes, 28 de mayo de 2001 8:49
> > > Para: joel.sherrill at OARcorp.com; Fernando RUIZ CASAS
> > (E-mail) (E-mail)
> > > Asunto: RE: RTEMS SS-20010525 Available
> > > In order to set up the last rtems snapshot this patch
> > resolve the little
> > > bugs
> > > in the telnetd environment already discussed.
> > > The psxchroot01 has been fixed.
> > > Regards
> > > Fernando RUIZ CASAS
> > > home: correo at fernando-ruiz.com
> > > work: fernando.ruiz at ctv.es
> > > > De: joel [mailto:joel]En nombre de Joel Sherrill
> > > > Enviado el: viernes, 25 de mayo de 2001 21:26
> > > > Para: rtems-users at OARcorp.com; rtems-snapshots at OARcorp.com
> > > > Asunto: RTEMS SS-20010525 Available
> > > > In ftp.oarcorp.com /pub/rtems/snapshots/rtems/current.
> > > > This snapshot includes improvements to the MIPS exception
> > > > and interrupt processing, the Robominds MRM BSP, more
> > > > configuration changes in the move to a BSP Kit, initial
> > > > support for telnetd, improvements to the motorola BSPs,
> > > > and some miscellaneous bug fixes.
> > > > I have modified the script to generate bzip since they are
> > > > about 40% smaller than gzip'ed images.  The script did not
> > > > correctly generate the diff so I did it by hand.  I will
> > > > get the script fixed before the next snapshot. :)
> > > > Enjoy.
> > > > Joel Sherrill, Ph.D.             Director of Research &
> > Development
> > > > joel at OARcorp.com                 On-Line Applications Research
> > > > Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> > > >    Support Available             (256) 722-9985
> > >                                        Name:
> > rtems-ss-20010125.shell.diff.bz2
> > >    rtems-ss-20010125.shell.diff.bz2    Type: Macintosh
> > StuffIt Archive (application/x-stuffit)
> > >                                    Encoding: base64
> > Angelo Fraietta
> > PO Box 859
> > Hamilton NSW 2303
> > Home Page
> > http://users.hunterlink.net.au/~maaaf/
> > There are those who seek knowledge for the sake of knowledge
> > - that is CURIOSITY
> > There are those who seek knowledge to be known by others -
> > that is VANITY
> > There are those who seek knowledge in order to serve - that is LOVE
> >     Bernard of Clairvaux (1090 - 1153)
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
