the parameter has no initial value before reference
careri/sed
careri at public.sta.net.cn
Tue Jul 17 10:42:03 UTC 2001
Hello,
You are right.
Thanks
Rong
-----Original Message-----
Sent: Tuesday, July 17, 2001 3:20 PM
To: careri/sed
Cc: rtems
Subject: Re: the parameter has no initial value before reference
carerie,
_ISR_Disable( level) is a makro. level is an output parameter and gets the
value inside _ISR_Disable().
Gerwin Pfab
Gerwin Pfab <pb at schenk.isar.de> Dr. Schenk Industriemesstechnik GmbH
Dipl. Ing. Einsteinstrasse 37
Software Engineering D-82152 Martinsried
Tel: +49-89-85695-0
Fax: +49-89-85695-200
On Tue, 17 Jul 2001, careri/sed wrote:
> Consider the following code in chain.c:
> void _Chain_Append(
> Chain_Control *the_chain,
> Chain_Node *node
> ISR_Level level;
> _ISR_Disable( level );
> _Chain_Append_unprotected( the_chain, node );
> _ISR_Enable( level );
> The parameter level has no initial value when _ISR_Disable is called.
> Rong
