the parameter has no initial value before reference
careri/sed careri at public.sta.net.cn
Tue Jul 17 10:42:13 UTC 2001
Hi,
You are right.
Thanks
Rong
-----Original Message-----
From:	Fernando RUIZ CASAS (E-mail) [SMTP:fernando.ruiz at ctv.es]
Sent:	Tuesday, July 17, 2001 3:28 PM
To:	'careri/sed'
Cc:	'Rtems-Users (E-mail)
Subject: 	RE: the parameter has no initial value before reference
Hi,
 IMHO ISR_Disable is a macro. (After browsing the code)
 Level is the parameter to CATCH the level.
 Level resumed once you call ISR_Enable.
Ah.. The macros and the unexpected behaviours.
Am I in the right answer?
Regards.
Fernando RUIZ CASAS
home:correo at fernando-ruiz.com
work:fernando.ruiz at ctv.es
> -----Mensaje original-----
> De: careri/sed [mailto:careri at public.sta.net.cn]
> Enviado el: martes, 17 de julio de 2001 2:08
> Para: rtems
> Asunto: the parameter has no initial value before reference
> Consider the following code in chain.c:
> void _Chain_Append(
>   Chain_Control *the_chain,
>   Chain_Node    *node
>   ISR_Level level;
>   _ISR_Disable( level );
>     _Chain_Append_unprotected( the_chain, node );
>   _ISR_Enable( level );
> The parameter level has no initial value when _ISR_Disable is called.
> Rong
