SEVERE Bug in mc68360 _ISR_Handler???
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Jul 18 12:41:50 UTC 2001
Thomas Doerfler wrote:
> Hello Chris, hello Joel,
> my network was running hot all night and the system is still alive
> and kicking. Your patch works fine and definitely cures the problem
> for all the "small" M68K processors.
> Joel, can you add the patch to the source tree?
> I think all M68k rtems users should be aware of that bug (and the
> patch), because it might lead to deadline misses concerning interrupt
> response time in rare conditions.
Chris could you repost it to the list. Eric Norum and I wondered
if the logic to enable it should be something like:
HAS_SEPARATE_STACKS==0 && COLDFIRE==0 && 060==0
I will then put this in the 4.5 branch, mainline, and
in a patches directory on the ftp server.
--joel
> Bye,
> Thomas.
> > > I will hack that into my test software and then make my network heat
> > > up again to blow hard against my poor RTEMS system :-)) . No need to
> > > publish it before it acutally works.
> > Try the attached patch. It is only 2 extra instructions :-)
> > Chris Johns, cjohns @ cybertec.com.au
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler Herbststrasse 8
> D-82178 Puchheim Germany
> email: Thomas.Doerfler at imd-systems.de
> PGP public key available at: http://www.imd-systems.de/pgp_key.htm
joel at OARcorp.com On-Line Applications Research
