Task Notes Polution
Fernando RUIZ CASAS (E-mail)
fernando.ruiz at ctv.es
Wed Jun 6 13:29:23 UTC 2001
Hi rtems-users.
Working in a reduced network-protocol
when a new shell task is created over a pseudo-terminal (ptn)
the TASK NOTES have been corrupted.
But only TWO task. The others tasks have not been corrupted.
Setting the CONFIGURE_EXTRA_TASK_STACKS and CONFIGURE_MEMORY_OVERHEAD
Increasing the task_stack in the shell_stack task and more tries but...
The task notes continue corrupted.
Which is the parameter to touch in order to avoid this problem?
Where is the first place to see?
Only the two first tasks have been corrupted.
I think that the code (it's the same for all the ptnX tasks) is good.
*********************Here the capture***************************************
RTEMS SHELL (Ver.1.0-FRC):/dev/ptn7. Jun 6 2001. 'help' to list commands.
ptn7 [/] #
ptn7 [/] # task
ID NAME PRIO STAT MODES EVENTS WAITID WAITARG NOTES
08010002 WDCT 1 DELAY P:T:nA NONE
08010003 net0 8 Wsem P:T:nA NONE 18010029 0xa0b3b10
08010004 net1 8 Wsem P:T:nA NONE 18010031 0xa0b3b10
08010005 tMST 8 READY P:T:nA NONE
08010006 tSLV 8 Wevnt P:T:nA NONE
08010007 tVIS 8 DELAY P:T:nA NONE
08010009 ptn0 8 Wsem P:T:nA NONE 1801000d 0xa0b3b10 0: 0x1388
1: 0x18 2: 0x5ffffc5 4: 0xa6a 5: 0xa01b82a 6: 0x100 7: 0xa01aa46 8:
0xa0f8a88 14: 0xa046420 15: 0xa0f8af8
0801000a ptn1 8 Wsem P:T:nA NONE 18010010 0xa0b3b10 0:
0xa02d076 1: 0xa0f88bc 2: 0xa009c80 3: 0xa0f88d0 4: 0x1b4 5: 0x4 6:
0xa0f88e4 7: 0xa0f88d0 8: 0xa02e42c 9: 0xa0f88c8 10: 0xa0f8a80 11: 0xa0f88d4
13: 0xa0f88dc
0801000b ptn2 8 Wsem P:T:nA NONE 18010013 0xa0b3b10
0801000c ptn3 8 Wsem P:T:nA NONE 18010016 0xa0b3b10
0801000d ptn4 8 Wsem P:T:nA NONE 18010019 0xa0b3b10
0801000e ptn5 8 Wsem P:T:nA NONE 1801001c 0xa0b3b10
0801000f ptn6 8 Wsem P:T:nA NONE 1801001f 0xa0b3b10
08010011 ptn7 8 READY P:T:nA NONE 18010030 0xa0b3b10
ptn7 [/] # config
config
INITIAL (startup) Configuration Info
WORKSPACE start: 0xa066ce8; size: 0x99318
TIME usec/tick: 10000; tick/timeslice: 50; tick/sec: 100
MAXIMUMS tasks: 20; timers: 2; sems: 106; que's: 0; ext's: 1
partitions: 0; regions: 1; ports: 0; periods: 0
ptn1 [/] # malloc
Malloc stats
avail:128k allocated:94k (74%) max:95k (74%) lifetime:0k freed:141k
Call counts: malloc:183 free:52 realloc:0 calloc:52
ptn1 [/] #
After EXIT from the 'corrupted' tasks
ptn0 [/] # exit
exit
logoff from the system...
Goodbye from RTEMS SHELL :-(
ptn7 [/] # task
task
ptn7 [/] #
After Reenter in the two ptnX Closed
ptn1 [/] # task
task
08010003 net0 8 Wsem P:T:nA NONE 18010029 0xa0abb00
08010004 net1 8 Wsem P:T:nA NONE 18010031 0xa0abb00
0801000b ptn2 8 Wsem P:T:nA NONE 18010013 0xa0abb00
0801000c ptn3 8 Wsem P:T:nA NONE 18010016 0xa0abb00
0801000d ptn4 8 Wsem P:T:nA NONE 18010019 0xa0abb00
0801000e ptn5 8 Wsem P:T:nA NONE 1801001c 0xa0abb00
0801000f ptn6 8 Wsem P:T:nA NONE 1801001f 0xa0abb00
08010011 ptn7 8 Wsem P:T:nA NONE 18010022 0xa0abb00
08010012 ptn0 8 Wsem P:T:nA NONE 1801000d 0xa0abb00
08010013 ptn1 8 READY P:T:nA NONE 18010028 0xa0abb00
ptn1 [/] #
Now all seems OK. Bizarrous problem. I'm confused.
