Problems with rtems_timer_create
Camilo Alejandro Arboleda
camilo.arboleda at ascom.com.co
Wed Jun 13 17:34:01 UTC 2001
Hello:
I am using RTEMS 4.5.0 with pc386 BSP. I have a problem (may be a bug?):
If I try to create a timer (using rtems_timer_create) I get a system
hang-up. At the very begining I though it was because a mistake in
configuration options, so I cheched them and they were OK.
Then I tried compiling my application for the Posix BSP. After that
I tried to follow the program execution using GDB, but it was not able
to insert a breakpoint inside rtems_timer_create function or even step
into it, at the calling point the application failed. So, I put a lot of
debuging messages inside rtems_timer_create (using printk), recompiled
the system and tried to run my application again (with pc386 BSP), but I
did not see a single message, only a system hang-up.
Have someone had the same problem? Could it be a gcc problem? or, did I
miss some configuration option while compiling RTEMS?
I thank you any help.
Ascom Colombia S.A.
http://www.ascom.com
URL: <http://lists.rtems.org/pipermail/users/attachments/20010613/cdc7b984/attachment.html>
