Problems with rtems_timer_create
Wed Jun 13 17:46:58 UTC 2001
Does the ticker.exe sample run on your hardware?
--joel
Camilo Alejandro Arboleda wrote:
> Hello:
> I am using RTEMS 4.5.0 with pc386 BSP. I have a problem (may be a bug?): If I
> try to create a timer (using rtems_timer_create) I get a system hang-up.  At
> the very begining I though it was because a mistake in configuration options,
> so I cheched them and they were OK.
> Then I tried compiling my application for the Posix BSP. After that I tried
> to follow the program execution using GDB, but it was not able to insert a
> breakpoint inside rtems_timer_create function or even step into it, at the
> calling point the application failed. So, I put a lot of debuging messages
> inside rtems_timer_create (using printk), recompiled the system and tried to
> run my application again (with pc386 BSP), but I did not see a single
> message, only a system hang-up.
> Have someone had the same problem? Could it be a gcc problem? or, did I miss
> some configuration option while compiling RTEMS?
> I thank you any help.
> Ascom Colombia S.A.
> http://www.ascom.com
