Building RTEMS using non-standard compiler names
steved94
steved94 at home.com
Mon Jun 4 01:25:17 UTC 2001
While I haven't specifically tried targeting a PowerPC I did try build Ada
targeting the x86 several months ago. I was working on RH Linux 6.2.
As I recall I found a symbolic described in the scripts for compiling Ada
files, and re-defined the value to something like GCC=gnatgcc. There were a
couple of small problems in the scripts elsewhere when I went to build. I
never succeeded. My problem is that RTEMS has moved on to using the elf
format while current public releases of GNAT are still based on GCC 2.8.1
which doesn't support elf for the x86 target.
It appears that GCC 3.0 will be out soon, and soon thereafter GNAT will be
integrated with the 3.1 release. This new version should resolve my problem
for targeting x86.
I hope this helps,
SteveD
----- Original Message -----
To: <rtems-users at oarcorp.com>
Sent: Sunday, June 03, 2001 10:14 AM
Subject: Building RTEMS using non-standard compiler names
> Hello,
> I would like to build RTEMS for PowerPC 555 and use it with Ada, using
Windows as
> a host.
> I have GNAT for powerPC, but the target C compiler (which is 2.8.1 based)
is named
> in a non-standard
> name (i.e. not powerpc-rtems-gcc). How do we tell RTEMS scripts to use
another
> compiler name?
> Thanks
> Avy
> astrominger at yahoo.com
> _________________________________________________________
> Do You Yahoo!?
> Get your free @yahoo.com address at http://mail.yahoo.com
