PPC new exception processing and interrupt controller
VALETTE Eric valette at crf.canon.fr
Tue Jun 5 08:25:31 UTC 2001
OUTWATER ~ KEITH J /5G3110 wrote:
> Greetings all -
> I'm trying to get a BSP for a generic powerPC 750 based system up and running
> and I'm having some trouble figuring out how exceptions should be processed.
> I'm looking at the motorola_powerpc BSP family, but this set of BSPs is much
> more complex than my application requires.
> I have an embedded system with only RAM, FLASH, a NS16550 UART and a custom
> interrupt controller.  That's it!
> Can anyone summarize the method/approach for getting interrupts and the
> interrupt controller hooked into RTEMS?  Initially, I'd be happy to get the UART
> interrupt and the internal decrementer runing.
> Thanks!
> Keith.
You have already execption support. Interrupt are just a particular kind
of exception. So I would chnage the exception handler associated with
exetrnal interrupts (see  BSP_rtems_irq_mng_init in irq_init.c to put
whatever function you want...).
Note that the low level code in irq_asm.c should be OK because it is not
BSP dependent (PIC dependent).
My two 0.02.
    __
   /  `                   	Eric Valette - Canon CRF
  /--   __  o _.          	Canon Development Europe Team Leader
(___, / (_(_(__         	Rue de la touche lambert
				35517 Cesson-Sevigne  Cedex
				FRANCE
Tel: +33 (0)2 99 87 68 91	Fax: +33 (0)2 99 84 11 30
E-mail: valette at crf.canon.fr	http://www.crf.canon.fr
