i386-rtems-gdb problem
Jeffrey Zhao
jeffreyzhao at shdv.com
Mon Jun 11 01:58:11 UTC 2001
Yes, i did as the 'getting started guide' told me to do. Even the one i
got
from the OARcorp.com does not accept these commands. But now, By
appending '-DRTEMS -DTARGET_i386' to the top-level Makefile CFLAGS and
'remote-rte.o rtems.o thread_rte.o rtems/rteRemDebXdr.o' to the
gdb/Makefile COMMON_OBJS, I've got an i386-rtems-gdb that can
accept these commands. I think the getting started guide or the
configure
script may be out-dated.
> -----Original Message-----
> From: Joel Sherrill [SMTP:joel.sherrill at OARcorp.com]
> Sent: Friday, June 08, 2001 8:36 PM
> To: Jeffrey Zhao
> Cc: rtems-users at oarcorp.com
> Subject: Re: i386-rtems-gdb problem
> Jeffrey Zhao wrote:
> > hi,
> > Recently, I used i386-rtems-gdb to debug an i386 rtems
> application,
> > but when i issued an
> > 'setrpcmode sun' command, it said this is an undefined command. so
> did
> > 'setdaemontype'.
> > Anyone can tell me what is wrong with my i386-rtems-gdb? thanks.
> TO get this configuration you have to build from source
> and configure for i386-RTEMS.
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
