Which Linux for RTEMS
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Wed Jun 13 15:14:28 UTC 2001
Matthew J.Fletcher wrote:
> Hi,
> I want to install Suse Linux 7.2 and RTEMS on my laptop.
> Will I be able to easily rebuild RTEMS?
> Or do you recommend specific Linux distributions.
> I dont know what target you are using, but the m68k series
> uses motorola's bdm debug port, however drivers for this
> only exist for the 2.2 kernel.
This topic is completely independent of particular distribution.
> SuSE are not known for the portablity of there RPMS,
Right.
But this doesn't matter here, because RTEMS's RPMS are portable and
independent of any particular distribution.
> but
> you should have no problems on any system if you build
> from source.
To achive binary backward compatibility, the RTEMS's binary RPMS are
are build on an old RH-6.x system (glibc-2.0.x). Thus, rebuilding
RTEMS RPMs on any more recent Linux-distribution is a good idea in
general.
Ralf
PS.: Please refrain from senting HTML/multipart-mime mails with
arkward disclaimers to mailing lists.
