rtems build fails for 20010525 ss w/o networking
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Tue Jun 19 13:25:03 UTC 2001
Jerry Needell wrote:
> If I try to build the 20010525 snapshot without networking enabled, it
> fails complaining that sys/socket.h is not found. This happens trying to
> compile telnetd.c. Has anyone else seen this, or does eveyone use enable
> networking? It builds fine with networking enabled.
> I am using binutils21.1, newlib1.9.0 and bot gcc 2.95.2 and gcc 3.0
> (20010614)
The bleeding edge :)
> BTW with gcc 3.0 the build faile if I enable POSIX - proble with
> arguments to va-arg. I'm
> still expeimenting with this. It builds w/o POSIX.
Which target, which BSP?
Ralf
