Cygwin host failure during make install all...
Silverio Diquigiovanni silverio.di at qem.it
Wed Jun 27 12:53:55 UTC 2001
The io_types.h file don't exist in sources of RTEMS.
I have fixed the problem removing io_types.h from
H_FILES = io_types.h .... & EXTRA_DIST = ....  in
/<user_home>/rtems-4.5.0/source/rtems-4.5.0/c/src/lib/libcpu/sh/sh7045/Makef
ile.am
After that I have restart the "configure" and "make install all".
I don't know if this is a valid soluction to the problem...
Suggestions are appreciated...
----- Original Message -----
From: "Silverio Diquigiovanni" <silverio.di at qem.it>
To: "Rtems Users Maillist" <rtems-users at oarcorp.com>
Sent: Wednesday, June 27, 2001 2:12 PM
Subject: Re: Cygwin host failure during configure...
> I have another problem...
> After "configure" I launch "make all install" and so I would either
> gensh1 & gensh2.
> gensh1 is made without problems...
> gensh2 throw an error during make phase...
> I attach a screen capture flow...
> Thank you for any suggestion
> Regards,
> Making all in libcpu
> make[4]: Entering directory
> `/home/SILVERIO_DIQUIGIOVANNI/rtems-4.5.0/build/sh-r
> tems-01/sh-rtems/c/gensh2/lib/libcpu'
> Making all in sh
> make[5]: Entering directory
> tems-01/sh-rtems/c/gensh2/lib/libcpu/sh'
> Making all in sh7045
> make[6]: Entering directory
> tems-01/sh-rtems/c/gensh2/lib/libcpu/sh/sh7045'
> Making all in include
> make[7]: Entering directory
> tems-01/sh-rtems/c/gensh2/lib/libcpu/sh/sh7045/include'
> make[7]: *** No rule to make target `io_types.h', needed by
> ./../gensh2/lib/include/sh/io_types.h'.  Stop.
> make[7]: Leaving directory
> `/home/SILVERIO_DIQUIGIOVANNI/rtems-4.5.0/build/sh-rt
> make[6]: *** [all-recursive] Error 1
> make[6]: Leaving directory
> make[5]: *** [all-recursive] Error 1
> make[5]: Leaving directory
> make[4]: *** [all-recursive] Error 1
> make[4]: Leaving directory
> make[3]: *** [all-recursive] Error 1
> make[3]: Leaving directory
> ems-01/sh-rtems/c/gensh2/lib'
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory
> ems-01/sh-rtems/c/gensh2'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
> ems-01/sh-rtems/c'
> make: *** [all-recursive] Error 1
> FYI I have this configure settings:
> ../../source/rtems-4.5.0/configure \
>     --target=sh-rtems \
>     --prefix=/home/SILVERIO_DIQUIGIOVANNI/rtems-4.5.0/sh-rtems-01/ \
>     --disable-multiprocessing \
>     --disable-posix \
>     --disable-itron \
>     --disable-networking \
>     --disable-rdbg
>     --disable-cxx \
>     --disable-tests
