RTEMS Build Problems on OpenBSD
Mike Siers mikes at poliac.com
Mon Mar 5 22:01:48 UTC 2001
Hi,
I took your advice and I switched back to use the 4.5.0 released version of
RTEMS.
I am still using the newer versions of the build tools.  I tried compling
RTEMS and this
time I got an error saying it could not find make.  I copied gmake to make
and I was
able to successfully build RTEMS!!
Should I switch back to the version of the build tools that are specified
with for
version 4.5.0?   Also, if you want to build the latest snapshot, what build
scripts
should you use?
Thanks for your help
Mike Siers
-----Original Message-----
From: siosion at sos1.sos.com.pl [mailto:siosion at sos1.sos.com.pl]On Behalf Of
Adam Szeliga
Sent: Monday, March 05, 2001 3:07 PM
To: rtems-users at oarcorp.com
Subject: Re: RTEMS Build Problems on OpenBSD
I think that you should return to rtems version 4.5.0.
You have mixed veriosn of tools and rtems system.
Adam Szeliga
Mike Siers wrote:
> Hi,
> I switched to use the following versions of the c tool files:
>   binutils-2.10 with patch dated 2000-11-02
>   gcc-2.95.2    with patch dated 2000-12-26
>   newlib-1.8.2  with patch dated 2000-08-28
>   c_build_scripts-4.5.0
