I can't build RTEMS.
Sergio Jesus
srg_j at newmail.net
Fri Mar 9 02:00:34 UTC 2001
I'm trying to install RTEMS release 4.5.0 on a i586 pc with RedHat6.2.
I followed all the instructions of the file 'started.pdf'.
I can successfully install the tools and DBG but when I try to build RTEMS I get the following message:
checking if cpu i386 is supported... yes
checking for make/custom/i386-rtems.cfg... configure: error: no
configure: error: ../../../rtems-4.5.0/c/configure failed for c
Could not successfully configure into build-i386-rtems!
In attachment I'm sending all the log of bit_rtems.
I used the bit scripts.
Can someone help me?
Thanks.
URL: <http://lists.rtems.org/pipermail/users/attachments/20010309/e0fd792a/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20010309/e0fd792a/attachment.obj>
