I can't build RTEMS.
Ralf Corsepius corsepiu at faw.uni-ulm.de
Fri Mar 9 09:13:44 UTC 2001
> Sergio Jesus wrote:
> I'm trying to install RTEMS release 4.5.0 on a i586 pc with
> RedHat6.2.
> I followed all the instructions of the file 'started.pdf'.
> I can successfully install the tools and DBG but when I try to
> build RTEMS I get the following message:
>     checking if cpu i386 is supported... yes
>     checking for make/custom/i386-rtems.cfg... configure: error:
> no
>     configure: error: ../../../rtems-4.5.0/c/configure failed for
> c
>     Could not successfully configure into build-i386-rtems!
> In attachment I'm sending all the log of bit_rtems.
> I used the bit scripts.
> ../rtems-4.5.0/configure --target=i386-rtems --prefix=/opt/rtems
> --disable-hwapi --disable-multiprocessing --enable-cxx
> --enable-rdbg --disable-tests --enable-networking
> --enable-posix --enable-itron
> --enable-rtemsbsp=i386-rtems
You are specifying an invalid BSP, --enable-rtemsbsp=pc386 is
probably what you want
Ralf
Ralf Corsepius
Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung
(FAW)
Helmholtzstr. 16, 89081 Ulm, Germany     Tel: +49/731/501-8690
mailto:corsepiu at faw.uni-ulm.de           FAX: +49/731/501-999
http://www.faw.uni-ulm.de
