help installing linux RPMS
Steve DeLaney steved at pacific-computing.com
Sat Mar 17 18:45:16 UTC 2001
I'm installing linux RPMs for 4.5.0 m68k and have the following dependency errors:
[root at firewall gnu]# rpm -i  m68k-rtems-binutils-2.9.5.0.24-1.i386.rpm
failed dependencies:
        rtems-base-binutils is needed by m68k-rtems-binutils-2.9.5.0.24-1
[root at firewall gnu]# rpm -i m68k-rtems-gcc-gcc2.95.2newlib1.8.2-7.i386.rpm
        m68k-rtems-binutils is needed by m68k-rtems-gcc-gcc2.95.2newlib1.8.2-7
        rtems-base-gcc is needed by m68k-rtems-gcc-gcc2.95.2newlib1.8.2-7
can someone help me locate
rtems-base-binutils
m68k-rtems-binutils
rtems-base-gcc
I assume these are RPMs
thanks,
Steve Delaney
Wideband Cable,. Inc.
URL: <http://lists.rtems.org/pipermail/users/attachments/20010317/9d0cc69b/attachment.html>
