help installing linux RPMS
Sat Mar 17 19:21:47 UTC 2001
> Steve DeLaney wrote:
> I'm installing linux RPMs for 4.5.0 m68k and have the following
> dependency errors:
> [root at firewall gnu]# rpm -i  m68k-rtems-binutils-2.9.5.0.24-1.i386.rpm
> failed dependencies:
>         rtems-base-binutils is needed by
> m68k-rtems-gcc-gcc2.95.2newlib1.8.2-7.i386.rpm
>         m68k-rtems-binutils is needed by
>         rtems-base-gcc is needed by
> can someone help me locate
> rtems-base-binutils
> m68k-rtems-binutils
> rtems-base-gcc
> I assume these are RPMs
See the following page.  It has links to them.
ftp://ftp.oarcorp.com/pub/rtems/releases/4.5.0/c_tools/linux_x86/index.html
> thanks,
> Steve Delaney
> Wideband Cable,. Inc.
