cross compiler problem with mips-rtems
Craig Graham
craig at data-uncertain.co.uk
Wed Mar 14 18:56:06 UTC 2001
On Wednesday 14 March 2001 11:57, Joel Sherrill wrote:
> > mike varga wrote:
> > Has anyone sucessfully built the cross compilers for mips-rtems. If so
> > did you have to do anything special?
> I regularly use the mips-rtems RPMS and the jmr3904 with the simulator
> in gdb.
I also use the rtems mips compilers straight from the rpm's - although, as
Joel knows, I'm not actually using them for rtems (different OS, different
libraries, but same cross compiler binaries).
Craig.
