cross compiler problem with mips-rtems
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Mar 14 11:57:11 UTC 2001
> mike varga wrote:
> Has anyone sucessfully built the cross compilers for mips-rtems. If so
> did you have to do anything special?
I regularly use the mips-rtems RPMS and the jmr3904 with the simulator
in gdb.
> I am using the latest snapshots but keep running into build errors.
> I am also using configure and make.
Could you provide some details?
joel at OARcorp.com On-Line Applications Research
