ACE/TAO on RTEMS
Sergei Organov
osv at javad.ru
Fri Mar 16 17:05:20 UTC 2001
Joel,
Are gcc flag '-ffunction-sections' and ld flag '--gc-sections' available for
your target? Do you use them?
BR,
Sergei Organov.
Joel Sherrill <joel.sherrill at oarcorp.com> writes:
> Hi,
> I am havnig some initial success building ACE/TAO. I have
> managed to build ACE and link all the tests without error.
> I am now compiling TAO. It appears that the ACE test executables
> are quite large. Any thoughts:
> bash$ sparc-rtems-size *Test
> text data bss dec hex filename
> 2156192 139232 43796 2339220 23b194 ARGV_Test
> 2156448 139104 43796 2339348 23b214 Aio_Platform_Test
> 2158960 139888 43796 2342644 23bef4 Atomic_Op_Test
> 2164400 140016 43796 2348212 23d4b4 Auto_IncDec_Test
> 2156928 139104 43796 2339828 23b3f4 Barrier_Test
> 2155728 139136 43796 2338660 23af64 Basic_Types_Test
> 2167744 140592 43796 2352132 23e404 Buffer_Stream_Test
> 2247104 142688 43796 2433588 252234 CDR_File_Test
> 2207968 141376 43796 2393140 248434 CDR_Test
> 2263824 144928 43796 2452548 256c44 Cache_Map_Manager_Test
> 2378256 157392 43796 2579444 275bf4 Cached_Accept_Conn_Test
> 2359312 154544 43796 2557652 2706d4 Cached_Conn_Test
> 2204864 141872 43796 2390532 247a04 Capabilities_Test
> I am looking at real .text, not executable file size so that
> mistake is out.
> This is a lot of C++ code so there might be some bad combination
> of options that is contributing to things. The compile options
> are "-fno-implicit-templates -fno-rtti -DACE_LACKS_RTTI ". Could
> I do better?
> I know ACE/TAO can be subsetted but am not looking at that since
> I am focuing on building everything. :)
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
