ACE/TAO on RTEMS
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Mar 16 17:24:26 UTC 2001
Sergei Organov wrote:
> Joel,
> Are gcc flag '-ffunction-sections' and ld flag '--gc-sections' available for
> your target? Do you use them?
I am test building on sparc-rtems (elf) which should support those
options.
Clearly that would be a nice thing to do. Does that work with the
regular RTEMS Makefile's or do we have to do something special
to account for the plethora of sections?
> BR,
> Sergei Organov.
> Joel Sherrill <joel.sherrill at oarcorp.com> writes:
> > Hi,
> > I am havnig some initial success building ACE/TAO. I have
> > managed to build ACE and link all the tests without error.
> > I am now compiling TAO. It appears that the ACE test executables
> > are quite large. Any thoughts:
> > bash$ sparc-rtems-size *Test
> > text data bss dec hex filename
> > 2156192 139232 43796 2339220 23b194 ARGV_Test
> > 2156448 139104 43796 2339348 23b214 Aio_Platform_Test
> > 2158960 139888 43796 2342644 23bef4 Atomic_Op_Test
> > 2164400 140016 43796 2348212 23d4b4 Auto_IncDec_Test
> > 2156928 139104 43796 2339828 23b3f4 Barrier_Test
> > 2155728 139136 43796 2338660 23af64 Basic_Types_Test
> > 2167744 140592 43796 2352132 23e404 Buffer_Stream_Test
> > 2247104 142688 43796 2433588 252234 CDR_File_Test
> > 2207968 141376 43796 2393140 248434 CDR_Test
> > 2263824 144928 43796 2452548 256c44 Cache_Map_Manager_Test
> > 2378256 157392 43796 2579444 275bf4 Cached_Accept_Conn_Test
> > 2359312 154544 43796 2557652 2706d4 Cached_Conn_Test
> > 2204864 141872 43796 2390532 247a04 Capabilities_Test
> > I am looking at real .text, not executable file size so that
> > mistake is out.
> > This is a lot of C++ code so there might be some bad combination
> > of options that is contributing to things. The compile options
> > are "-fno-implicit-templates -fno-rtti -DACE_LACKS_RTTI ". Could
> > I do better?
> > I know ACE/TAO can be subsetted but am not looking at that since
> > I am focuing on building everything. :)
> > Joel Sherrill, Ph.D. Director of Research & Development
> > joel at OARcorp.com On-Line Applications Research
> > Ask me about RTEMS: a free RTOS Huntsville AL 35805
> > Support Available (256) 722-9985
