make cross -> as: unrecognized option `-mc68020'
Ralf Corsepius corsepiu at faw.uni-ulm.de
Wed Mar 21 14:25:03 UTC 2001
Chris Stich wrote:
> Hi,
> thank you for your response.
> Some more questions ;-) :
> Must the "normal" as in /bin support mc68xxx?
No. This is supposed to be the native assembler (here:
i386-pc-cygwin).
> Because I built the m68k-rtems-as.exe in the
> D:\cygwin\gcc-m68k-rtems\bin path.
I am not sure what you are trying to say.
PREFIX/bin/m68k-rtems-as and PREFIX/m68k-rtems/bin/as are supposed
to be the cross-assemblers.
> And I understand, that the "make cross" takes than the as with the
> "m68k-rtems-" prefix in this directory.
Yep.
> Maybe in one of the makefiles there is the prefix for the cross missing?
> Am I wrong?
I presume, you might have PREFIX/m68k-rtems/bin in $PATH.
You should have the directory in $PATH which contains m68k-rtems-as.
Ralf
Ralf Corsepius
Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung
(FAW)
Helmholtzstr. 16, 89081 Ulm, Germany     Tel: +49/731/501-8690
mailto:corsepiu at faw.uni-ulm.de           FAX: +49/731/501-999
http://www.faw.uni-ulm.de
