Cygwin Build
Paul Evans paule at martex.gen.oh.us
Thu May 3 17:27:28 UTC 2001
Hello All,
I'm having a problem building RTEMS-4.5.0 under the current Cygwin
environment. It would appear from the configure output that Cygwin
isn't being detected. Is this an autoconf problem  that can be overridden,
or a symptom of something else? (The toolchain is the precompiled one from
OAR and is working correctly)
Thanks for any help,
    -Paul
--Output follows (PS1 is 2 lines)--
paule at PIPPIN ~
$ set | grep ^PATH=
PATH=/opt/rtems/bin:/usr/local/bin:/usr/bin:/bin:/c/Python21:/c/Perl/bin:/c/
WINN
T/system32:/c/WINNT:/c/WINNT/System32/Wbem
paule at PIPPIN ~/build
$ cat build_cmd
../rtems-4.5.0/configure --target=m68k \
    --disable-posix --disable-tcpip --disable-cxx \
    --enable-rtemsbsp=m68k-rtems\
    --prefix=/opt/rtems
$ bash build_cmd
loading cache ./config.cache
checking for RTEMS Version... 4.5.0
checking host system type... i386-pc-cygwin32
checking target system type... m68k-unknown-none
checking build system type... i386-pc-cygwin32
checking rtems target cpu... m68k
checking for a BSD compatible install... (cached) /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... (cached) yes
checking for working aclocal... found
checking for working autoconf... found
checking for working automake... found
checking for working autoheader... found
checking for working makeinfo... found
checking whether to enable maintainer-specific portions of Makefiles... no
checking if the test suites are enabled? ... no
checking if cpu m68k is supported... yes
creating ./config.status
creating Makefile
creating tools/Makefile
creating make/Makefile
creating make/custom/Makefile
creating make/Templates/Makefile
creating make/compilers/Makefile
creating doc/Makefile
configuring in tools/build
running /bin/sh
../../../rtems-4.5.0/tools/build/configure  --target=m68k --disa
ble-posix --disable-tcpip --disable-cxx --enable-rtemsbsp=m68k-rtems --prefi
x=/o
pt/rtems --cache-file=../.././config.cache --srcdir=../../../rtems-4.5.0/too
ls/b
uild
loading cache ../.././config.cache
checking for Cygwin environment... no
checking for mingw32 environment... no
checking for executable suffix... configure: error: installation or
configuratio
n problem: compiler cannot create executables.
configure: error: ../../../rtems-4.5.0/tools/build/configure failed for
tools/bu
ild
