a question about Code Space Requirements
red-eye at 263.net
red-eye at 263.net
Tue May 22 13:14:19 UTC 2001
rtems-users£¬
Hello,
I would like to use RTEMS on a board with the ERC32 processor
when i have compiler the hello-world. i found the ELF file "
hello-world.exe" was too big:about 800K bytes .i use sparc-rtems-
objcopy tool to move the debugg information in it.then the file
"hello-world.exe"become 115kbytes
ls -al hello-world.exe
-rwxrwxr-x 1 root root 115209 May 21 14:08 rtems-hello1.exe
sparc-rtems-size hello-world.exe
text data bss dec hex filename
84608 4472 19556 108636 1a85c rtems-hello1.exe
it was big too! because:
i see the RTEMS SPARC Applications Supplement pdf file,
Chapter 8 memory require specifies
> Minimum 28,288
> Maximum 50,432
helloworld application code i think about 2k--3kbytes .because
i use sparc-rtems-objcopy on test.o file
it become 2,340 bytes
the left about 115k-50k-3k=62k is what?
all the 62k is the console driver and printf?
anybody can tell me which compose the 115kbytes(the size of hello-world.exe).
thaks alot
_____________________________________________
ÊýÂë²úÆ·ÐÂÉÏÊУ¬¿á http://shopping.263.net/category21.htm
¾«Æ·Ð¡¼ÒµçÓÏÄÈÈÂô http://shopping.263.net/category23.htm
