termios problem
Andrew Maximov
amaximus at mail.ru
Tue May 22 07:08:22 UTC 2001
There is some problems with termios. System hangs after I try
to output to console more than 64 characters. My configuration:
HARDWARE: MC68MH360
RTEMS: RTEMS-4.5.0
BSP: m68k
I wrote a simple test to demonstrate this problem.
Here is a output screen:
TERMIOS TEST STARTED.
hung after 5 seconds
hung after 4 seconds
hung after 3 seconds
hung after 2 seconds
hung after 1 seconds
and C source:
#define CONFIGURE_INIT
#include <bsp.h>
static
void (*test_func_ptr)();
static
void test_3()
printf("you should not see this.\n");
static
void test_2()
printf("this is first loooong string !!!!!!!!!!!!!!!\n");
printf("this is second loooong string !!!!!!!!!!!!!!!!!!!\n");
test_func_ptr = test_3;
static
void test_1()
static int live_period = 5;
printf("hung after %d seconds\n",live_period--);
if ( live_period == 0 ) test_func_ptr = test_2;
rtems_timer_service_routine
test_timer_proc( rtems_id timer_id, void *unused )
test_func_ptr();
rtems_timer_reset( timer_id );
rtems_task Init(
rtems_task_argument argument
rtems_status_code status;
rtems_name name;
rtems_interval ticks_per_second;
rtems_id test_timer;
printf("\nTERMIOS TEST STARTED.\n");
rtems_clock_get( RTEMS_CLOCK_GET_TICKS_PER_SECOND, &ticks_per_second );
name = rtems_build_name( 'T', 'E', 'S', 'T' );
status = rtems_timer_create( name, &test_timer );
if ( status != RTEMS_SUCCESSFUL ) rtems_fatal_error_occurred( status );
test_func_ptr = test_1;
status = rtems_timer_fire_after( test_timer,
ticks_per_second,
test_timer_proc,
NULL);
rtems_task_suspend( RTEMS_SELF );
exit(0);
/* configuration information */
#define CONFIGURE_MAXIMUM_TASKS 32
#define CONFIGURE_MAXIMUM_PERIODS 1
#define CONFIGURE_MAXIMUM_SEMAPHORES 32
#define CONFIGURE_MAXIMUM_TIMERS 32
#define CONFIGURE_INIT_TASK_PRIORITY 1
#define CONFIGURE_INIT_TASK_INITIAL_MODES ( RTEMS_PREEMPT |
RTEMS_TIMESLICE | RTEMS_ASR | RTEMS_INTERRUPT_LEVEL(0) )
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define STACK_CHECKER_ON
#define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_TEST_NEEDS_TIMER_DRIVER
rtems_driver_address_table Device_drivers[] = {
#ifdef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
CONSOLE_DRIVER_TABLE_ENTRY,
#endif
#ifdef CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
CLOCK_DRIVER_TABLE_ENTRY,
#endif
#ifdef CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
STUB_DRIVER_TABLE_ENTRY,
#endif
{NULL, NULL, NULL, NULL, NULL, NULL}
#include <confdefs.h>
