Cygwin Build
Paul Evans
paule at martex.gen.oh.us
Fri May 4 13:41:21 UTC 2001
Hi again,
Before any one wastes time on this. I needed
"export CC=gcc" before I ran configure. Which
I thought I had. but my bash start files were mixed
up.
However now, it fails with:
checking for make/custom/m68k-rtems.cfg... configure: error: no
configure: error: ../../../rtems-4.5.0/c/configure failed for c
The second to last line looks cut off. Does anyone know
what "error: no" means?
*sigh*
Thanks,
-Paul
----- Original Message -----
To: <rtems-users at oarcorp.com>
Sent: Thursday, May 03, 2001 1:27 PM
Subject: Cygwin Build
> Hello All,
> I'm having a problem building RTEMS-4.5.0 under the current Cygwin
> environment. It would appear from the configure output that Cygwin
> isn't being detected. Is this an autoconf problem that can be overridden,
> or a symptom of something else? (The toolchain is the precompiled one from
> OAR and is working correctly)
> Thanks for any help,
> -Paul
> --Output follows (PS1 is 2 lines)--
> paule at PIPPIN ~
> $ set | grep ^PATH=
PATH=/opt/rtems/bin:/usr/local/bin:/usr/bin:/bin:/c/Python21:/c/Perl/bin:/c/
> WINN
> T/system32:/c/WINNT:/c/WINNT/System32/Wbem
> paule at PIPPIN ~/build
> $ cat build_cmd
> ../rtems-4.5.0/configure --target=m68k \
> --disable-posix --disable-tcpip --disable-cxx \
> --enable-rtemsbsp=m68k-rtems\
> --prefix=/opt/rtems
<cut>
