i386/parallel port
Correo Fernando-ruiz (E-mail)
correo at fernando-ruiz.com
Tue May 8 20:20:03 UTC 2001
> -----Mensaje original-----
> De: rwas rwas [mailto:mc68332 at yahoo.com]
> Enviado el: martes, 08 de mayo de 2001 20:19
> Para: rtems-users at oarcorp.com
> Asunto: RE: i386/parallel port
> > I'm working around the multiuser shell environment.
> Kewl!
> > The system on VxWorks isn't known by me.
> > If you can explain me the environment perhaps I can
> > work in this line.
> Sure, the shell is a single user environment which can
> be accessed either by console or telnet.
> From the console one can do basic disk operation
> required to load and manipulate files and executables.
> The main thing that's nice about the vxworks
> userinterface is that one can load modules (read *.o)
> on the fly, then use console task commands to run
> them.
> One can call any function within in a module simply by
> typing it in on the command line. At any time one can
> manipulate variables from the command line.
> All memory is shared memory unless made specifically
> private.
> All this is probably a tall order, but just the
> ability to test the health of the os in a system
> before trying execute large blocks of code would be
> IMO very useful.
Basically the same line. This is ready now in RTEMS.
But not documented. Sorry. :-(
> > Questions,
> About a million of them.
> > Sugg?
> > Please don't hesitate to ask me.
> > Fernando RUIZ CASAS
> > home:correo at fernando-ruiz.com
> > work:fernando.ruiz at ctv.es
> I'd be very happy to work with the development
> community on this OS. I fear it will be some time
> before I can get through my learning curve on it
> however.
With a little effort in the begining you will ready quickly.
It's easy RTEMS if you known other RTOS envs.
You have PC386 to learn and after you can develope your BSP for your
hardware.
> Robert Wasierski
> Dynacs Engineering
> 505 846-5581
> __________________________________________________
> Do You Yahoo!?
> Yahoo! Auctions - buy the things you want at great prices
> http://auctions.yahoo.com/
