how to tailor the RTEMS application?
Joel Sherrill
joel.sherrill at OARcorp.com
Thu May 24 18:57:13 UTC 2001
red-eye at 263.net wrote:
> i am using ERC32CCS,i compiler the "hello-world" sample
> the exe file without debug information was 115k bytes
> it is too big ,how can i make it more small?
> has the config using confdefs.h in the "hello-world" already tailor the RTOS to the smallest?
confdefs.h just reduces RAM requirements at run-time, it does not leave
out code pieces.
A lot depends on the particular configure command given and how many
dependencies are in the BSP. printf itself is large. See how
large samples/minimum is in comparison.
You may have posix and itron apis enabled.
> * Simple test program -- simplified version of sample test hello.
> #define TEST_INIT
> #include <bsp.h>
> #include <stdio.h>
> rtems_task Init(
> rtems_task_argument ignored
> printf( "\n\n*** HELLO WORLD TEST ***\n" );
> printf( "Hello World\n" );
> printf( "*** END OF HELLO WORLD TEST ***\n" );
> exit( 0 );
> /* configuration information */
> #define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_INIT
> #include <confdefs.h>
> /* end of file */
> is the confdefs.h the only way to tailor RTEMS?
> thaks alot
> _____________________________________________
> ÊýÂë²úÆ·ÐÂÉÏÊУ¬¿á http://shopping.263.net/category21.htm
> ¾«Æ·Ð¡¼ÒµçÓÏÄÈÈÂô http://shopping.263.net/category23.htm
joel at OARcorp.com On-Line Applications Research
