problems adding targets to libfs
Matthew J Fletcher
amimjf at connectfree.co.uk
Mon Nov 26 11:32:31 UTC 2001
Hi,.
I've been trying to add a new filesystem into libfs but have gotten pretty
stuck in rtems quite impressive build system,.. :)
[ not very helpfull error message ]
Making all in wrapup
gmake[4]: Entering directory `/xfs/rtems-build/c/posix/libfs/wrapup'
gmake[4]: *** No rule to make target `../src/jffs/o-optimize/libjffs.a',
needed by `o-optimize/libfs.a'. Stop.
the error seems to be that the directory (and files) within
'rtems-ss-20011025/c/src/libfs/jff' were not copied across
to 'rtems-build/c/posix/libfs/jffs' i.e no attempt was made to create the
directory.
as with other autoconf / automake based systems i have edited
the following files,.
/libfs/src/Makefile.am // added extra subdir
/libfs/src/wrapup/Makefile.am // added extra lib to libfs
/libfs/configure.ac // added extra makefile
so the question is what am i missing ?
for some more details on what i did i have included a [ edited ] patch
of my build efforts,..
[ - patch begins - ]
diff -ru2 ./rtems-ss-20011025/c/src/exec/sapi/include/confdefs.h
./rtems-ss-20011025-clean/c/src/exec/sapi/include/confdefs.h
--- ./rtems-ss-20011025/c/src/exec/sapi/include/confdefs.h Mon Nov 26
10:22:50 2001
+++ ./rtems-ss-20011025-clean/c/src/exec/sapi/include/confdefs.h Tue Oct 16
20:05:28 2001
@@ -104,5 +104,4 @@
#include <imfs.h>
-#include <jffs.h> /* mjf - 28/11/2001 - added initial jffs filesystem */
#ifdef CONFIGURE_INIT
@@ -112,6 +111,4 @@
#ifdef CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
&IMFS_ops,
-#elif CONFIGURE_USE_JFFS_AS_BASE_FILESYSTEM /* mjf - using jffs as base
filesystem */
- &JFFS_ops,
#else /* using miniIMFS as base filesystem */
&miniIMFS_ops,
diff -ru2 ./rtems-ss-20011025/c/src/libfs/configure.ac
./rtems-ss-20011025-clean/c/src/libfs/configure.ac
--- ./rtems-ss-20011025/c/src/libfs/configure.ac Mon Nov 26 10:07:17 2001
+++ ./rtems-ss-20011025-clean/c/src/libfs/configure.ac Fri Oct 12 19:44:57
2001
@@ -33,5 +33,4 @@
src/Makefile
src/imfs/Makefile
-src/jffs/Makefile
wrapup/Makefile
diff -ru2 ./rtems-ss-20011025/c/src/libfs/src/Makefile.am
./rtems-ss-20011025-clean/c/src/libfs/src/Makefile.am
--- ./rtems-ss-20011025/c/src/libfs/src/Makefile.am Wed Nov 21 22:09:38 2001
+++ ./rtems-ss-20011025-clean/c/src/libfs/src/Makefile.am Wed Oct 18 19:10:55
2000
@@ -5,7 +5,5 @@
AUTOMAKE_OPTIONS = foreign 1.4
-SUBDIRS = imfs jffs
-# mjf - 21/11/2001 - added jffs
+SUBDIRS = imfs
include $(top_srcdir)/../../../automake/subdirs.am
Only in ./rtems-ss-20011025/c/src/libfs/src: jffs
diff -ru2 ./rtems-ss-20011025/c/src/libfs/wrapup/Makefile.am
./rtems-ss-20011025-clean/c/src/libfs/wrapup/Makefile.am
--- ./rtems-ss-20011025/c/src/libfs/wrapup/Makefile.am Mon Nov 26 09:27:46
2001
+++ ./rtems-ss-20011025-clean/c/src/libfs/wrapup/Makefile.am Wed Oct 18
19:10:55 2000
@@ -16,10 +16,5 @@
#endif
-# mjf - 21/11/2001 - added jffs support
-#if HAS_JFFS
-JFFSLIB = ../src/jffs/$(ARCH)/libjffs.a
-#endif
-TMP_LIBS = $(IMFSLIB) $(JFFSLIB)
+TMP_LIBS = $(IMFSLIB)
$(PROJECT_RELEASE)/lib/$(LIBNAME)$(LIB_VARIANT).a: $(LIB)
diff -ru2 ./rtems-ss-20011025/c/src/libfs/wrapup/Makefile.in
./rtems-ss-20011025-clean/c/src/libfs/wrapup/Makefile.in
--- ./rtems-ss-20011025/c/src/libfs/wrapup/Makefile.in Wed Nov 21 22:15:33
2001
+++ ./rtems-ss-20011025-clean/c/src/libfs/wrapup/Makefile.in Thu Oct 25
23:03:49 2001
@@ -245,12 +245,7 @@
#if HAS_IMFS
IMFSLIB = ../src/imfs/$(ARCH)/libimfs.a
-#endif
-# if HAS_JFFS
#endif
PROJECT_TOOLS = $(PROJECT_RELEASE)/build-tools
diff -ru2 ./rtems-ss-20011025/c/src/libmisc/shell/cmds.c
./rtems-ss-20011025-clean/c/src/libmisc/shell/cmds.c
--- ./rtems-ss-20011025/c/src/libmisc/shell/cmds.c Mon Nov 26 10:28:36 2001
+++ ./rtems-ss-20011025-clean/c/src/libmisc/shell/cmds.c Thu Aug 9 23:08:45
2001
@@ -44,5 +44,4 @@
#include <imfs.h>
-#include <jffs.h> /* mjf - 28/11/2001 - jffs filesystem support - mkfs.jffs
#include <rtems/shell.h>
[ - patch ends - ]
regards
Matthew J Fletcher amimjf at connectfree.co.uk
Software Engineering Matthew.Fletcher at student.shu.ac.uk
www.amimjf.org ICQ amimjf 44193496
Since when did ignorance become a point of view ??
