problems adding targets to libfs
Matthew J Fletcher
amimjf at connectfree.co.uk
Tue Nov 27 14:10:03 UTC 2001
On Tuesday 27 Nov 2001 8:37 pm, you wrote:
> With one exception, the stuff in your patch appears OK at 1st glance.
> My reading of the diff is that it is backwards. :)
err,. yes,.. sorry, its the old src,dest vs dest,src thing again, at lest you
have a fairly nice patch to remove all my rubbish :)
> The remaining questions are:
> 1. Did you run bootstrap in the libfs directory?
yes,. it complained about not having the EMBEDDED_C_ and UNIX_C variables,
but nothing else.
> 2. Did the make descend into src/jffs?
no, the directory was not even created in my build dir,.
> 3. Did it create the src/jffs/o-optimize/libjffs.a file? Is it there?
nope.
> 4. For whatever reason, did you try a rebuild from scratch just in
> case?
loads of times,.
> I assume there is not a typo in the name libjffs.a. :)
> Is this the Linux JFFS? And did the licensing question get resolved?
well i took it from the 2.4.8 tree sources, but its hardly a linux fs
(looking at all the compatablity stuff that was added).
licensing,. ? (missed that discussion, sorry) its under the GPL2, jffs2 is
issued under the GPL2 and RedHats eCos licence,..
is that a problem ?
regards
Matthew J Fletcher amimjf at connectfree.co.uk
Software Engineering Matthew.Fletcher at student.shu.ac.uk
www.amimjf.org ICQ amimjf 44193496
Since when did ignorance become a point of view ??
