Interrupt latency problems on MPC860
Phil Torre
ptorre at zetron.com
Wed Nov 14 22:27:40 UTC 2001
On Wed, Nov 14, 2001 at 02:49:06PM -0600, Joel Sherrill wrote:
> Moreover, this really may be tough to attain on the PowerPC
> architecture without VERY special care. The PowerPC by default does
> not really have interrupt priority or (without work) nesting of
> interrupts. So all you have to do is take > 79 usecs to process
> an interrupt and you are nailed. Since (I am pretty sure about this)
> interrupts are disabled from the time a handler is vectored by HW
> until the entire ISR returns, you have a long window there.
Originally, this was the case. There is a comment in irq_stub.S,
right after _ISR_Nest_level is incremented, which says "From here on
out, interrupts can be re-enabled. RTEMS convention says not". I
added an instruction there to re-enable interrupts by setting MSR[EE],
but it seems to make no difference.
Am I right in thinking that there should only be two times when maskable
interrupts are disabled: In between the hardware vector and nesting,
and in between rtems_interrupt_disable() and rtems_interrupt_enable()?
Thanks,
-Phil
Phil Torre phone: 425-820-6363 x234
Design Engineer email: ptorre at zetron.com
Switching Systems Group fax: 425-820-7031
Zetron, Inc. web: http://www.zetron.com
