undefined reference to `c_rtems_main' with rtems-ss-20011025 and posix bsp
Thu Nov 22 01:13:06 UTC 2001
Matthew J Fletcher wrote:
> Hi,.
> just to let you know that under rtems-ss-20011025 and the posix bsp you cant
> link properly against 'c_rtems_main', (from main.c), librtemsall.a does
> contain main.o,... so it built ok,.
> (there is a load of information bellow, but i will cut to the chase now)
> i checked that c_rtems_main, (in main.c) is transformed to main() correctly
> and it was,.. (see objdump bellow)
> i dont know quite how the link process got muddled so that bootcard.c
> was looking for c_rtems_main() instead of main(), but a quick hack
> to call main() instead of c_rtems_main and everything works just fine.
This is a side-effect of moving main() into user space.  On the POSIX
BSP,
we really do still need to have the special main in the BSP AFAIK.
Here is the patch to posix/unix/startup/Makefile.am.
RCS file:
/usr1/CVS/rtems/c/src/lib/libbsp/unix/posix/startup/Makefile.am,v
retrieving revision 1.3
retrieving revision 1.4
diff -u -r1.3 -r1.4
--- rtems/c/src/lib/libbsp/unix/posix/startup/Makefile.am
2000/09/05 15:55:02     1.3
+++ rtems/c/src/lib/libbsp/unix/posix/startup/Makefile.am
2001/11/07 23:21:22     1.4
@@ -1,5 +1,5 @@
-##  $Id: Makefile.am,v 1.3 2000/09/05 15:55:02 joel Exp $
+##  $Id: Makefile.am,v 1.4 2001/11/07 23:21:22 joel Exp $
 AUTOMAKE_OPTIONS = foreign 1.4
@@ -11,7 +11,7 @@
 if HAS_CXX
 C_MAIN_C_FILES =
 else
-C_MAIN_C_FILES = main.c bootcard.c
+C_MAIN_C_FILES = main.c
 endif
 # C sources
> in case it helps this all worked just fine with rtems-ss-20010126.
> a fairly usless error message,..
> gmake[5]: Entering directory `/xfs/rtems-build/c/posix/tests/samples/hello'
> mkdir o-optimize
> gcc --pipe -B../../../../../ -B../../../../../posix/lib/ -specs bsp_specs
> -qrtems     -ansi -fasm   -D_BSD_SOURCE    -O2 -g -Wall  -o o-optimize/init.o
> -c ../../../../../../rtems-ss-20011025/c/src/tests/samples/hello/init.c
> ../../../../../../rtems-ss-20011025/c/src/tests/samples/hello/init.c: In
> function `Init':
> ../../../../../../rtems-ss-20011025/c/src/tests/samples/hello/init.c:33:
> warning: implicit declaration of function `exit'
> -qrtems -g -Wall  -ansi -fasm   -D_BSD_SOURCE     -L ../../../../../posix/lib
>   -O2  -o o-optimize/hello.exe o-optimize/init.o
> ../../../../../posix/lib/no-dpmem.rel ../../../../../posix/lib/no-event.rel
> ../../../../../posix/lib/no-msg.rel ../../../../../posix/lib/no-mp.rel
> ../../../../../posix/lib/no-part.rel ../../../../../posix/lib/no-signal.rel
> ../../../../../posix/lib/no-timer.rel ../../../../../posix/lib/no-rtmon.rel
> ../../../../../posix/lib/librtemsall.a(bootcard.o): In function `boot_card':
> /xfs/rtems-build/c/posix/lib/libbsp/unix/posix/startup/../../../../../../../../rtems-ss-20011025/c/src/lib/libbsp/shared/bootcard.c:127:
> collect2: ld returned 1 exit status
> just to get some more information i tired,...
> objdump -atxS librtemsall.a > outfile
> and c_rtems_main() seems to have turned into
> main(),..  correctly so no problem there,.
> main.o:     file format elf32-i386
> r--r--r-- 504/535  50740 Nov 21 21:29 2001 main.o
> architecture: i386, flags 0x00000011:
> HAS_RELOC, HAS_SYMS
> start address 0x00000000
> SYMBOL TABLE:
> 00000000 l    df *ABS*  00000000 main.c
> 00000000 l    d  .text  00000000
> 00000000 l    d  .data  00000000
> 00000000 l    d  .bss   00000000
> 00000000 l    d  .rodata.str1.1 00000000
> 00000000 l       .rodata.str1.1 00000000 .LC0
> 00000000 l    d  .stab  00000000
> 00000000 l    d  .stabstr       00000000
> 00000000 l    d  .comment       00000000
> 00000000 g     F .text  00000074 main
> 00000000         *UND*  00000000 rtems_argc
> 00000000         *UND*  00000000 rtems_argv
> 00000000         *UND*  00000000 bsp_start
> 00000004       O *COM*  00000004 rtems_progname
> 00000000         *UND*  00000000 bsp_isr_level
> 00000000         *UND*  00000000 rtems_initialize_executive_late
> 00000000         *UND*  00000000 stdout
> 00000000         *UND*  00000000 fflush
> 00000000         *UND*  00000000 stderr
> 00000000         *UND*  00000000 bsp_cleanup
> Disassembly of section .text:
> 00000000 <main>:
> int main(
>   int argc,
>   char **argv
>    0:   55                      push   %ebp
>    1:   89 e5                   mov    %esp,%ebp
>    3:   56                      push   %esi
>    4:   53                      push   %ebx
>    5:   8b 75 0c                mov    0xc(%ebp),%esi
>    8:   8b 5d 08                mov    0x8(%ebp),%ebx
>    b:   83 e4 f0                and    $0xfffffff0,%esp
>   rtems_argc = argc;
>    e:   89 1d 00 00 00 00       mov    %ebx,0x0
>                         10: R_386_32    rtems_argc
>   rtems_argv = argv;
>   14:   89 35 00 00 00 00       mov    %esi,0x0
>                         16: R_386_32    rtems_argv
>   bsp_start();
>   1a:   e8 fc ff ff ff          call   1b <main+0x1b>
>                         1b: R_386_PC32  bsp_start
>   if ((argc > 0) && argv && argv[0])
>   1f:   85 db                   test   %ebx,%ebx
>   21:   7e 45                   jle    68 <main+0x68>
>   23:   85 f6                   test   %esi,%esi
>   25:   74 41                   je     68 <main+0x68>
>   27:   8b 06                   mov    (%esi),%eax
>   29:   85 c0                   test   %eax,%eax
>   2b:   74 3b                   je     68 <main+0x68>
>       rtems_progname = argv[0];
>   2d:   a3 00 00 00 00          mov    %eax,0x0
>                         2e: R_386_32    rtems_progname
>   else
>       rtems_progname = "RTEMS";
>    *  Start multitasking
>   rtems_initialize_executive_late( bsp_isr_level );
>   32:   83 ec 0c                sub    $0xc,%esp
>   35:   8b 35 00 00 00 00       mov    0x0,%esi
>                         37: R_386_32    bsp_isr_level
>   3b:   56                      push   %esi
>   3c:   e8 fc ff ff ff          call   3d <main+0x3d>
>                         3d: R_386_PC32  rtems_initialize_executive_late
>    * Returns when multitasking is stopped
>    * This allows our destructors to get run normally
>   fflush( stdout );
>   41:   5b                      pop    %ebx
>   42:   8b 0d 00 00 00 00       mov    0x0,%ecx
>                         44: R_386_32    stdout
>   48:   51                      push   %ecx
>   49:   e8 fc ff ff ff          call   4a <main+0x4a>
>                         4a: R_386_PC32  fflush
>   fflush( stderr );
>   4e:   5a                      pop    %edx
>   4f:   a1 00 00 00 00          mov    0x0,%eax
>                         50: R_386_32    stderr
>   54:   50                      push   %eax
>   55:   e8 fc ff ff ff          call   56 <main+0x56>
>                         56: R_386_PC32  fflush
>   bsp_cleanup();
>   5a:   e8 fc ff ff ff          call   5b <main+0x5b>
>                         5b: R_386_PC32  bsp_cleanup
>   return 0;
>   5f:   8d 65 f8                lea    0xfffffff8(%ebp),%esp
>   62:   5b                      pop    %ebx
>   63:   31 c0                   xor    %eax,%eax
>   65:   5e                      pop    %esi
>   66:   5d                      pop    %ebp
>   67:   c3                      ret
>   68:   c7 05 00 00 00 00 00    movl   $0x0,0x0
>   6f:   00 00 00
>                         6a: R_386_32    rtems_progname
>                         6e: R_386_32    .LC0
>   72:   eb be                   jmp    32 <main+0x32>
>   74:   8d b6 00 00 00 00       lea    0x0(%esi),%esi
>   7a:   8d bf 00 00 00 00       lea    0x0(%edi),%edi
> mallocfreespace.o:     file format elf32-i386
> r--r--r-- 504/535  52668 Nov 21 21:29 2001 mallocfreespace.o
> HAS_RELOC, HAS_SYMS
> Sections:
> Idx Name          Size      VMA       LMA       File off  Algn
>   0 .text         00000030  00000000  00000000  00000040  2**4
>                   CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE
>   1 .data         00000000  00000000  00000000  00000070  2**2
>                   CONTENTS, ALLOC, LOAD, DATA
>   2 .bss          00000000  00000000  00000000  00000070  2**2
>                   ALLOC
>   3 .stab         00002bec  00000000  00000000  00000070  2**2
>                   CONTENTS, RELOC, READONLY, DEBUGGING
>   4 .stabstr      00009de2  00000000  00000000  00002c5c  2**0
>                   CONTENTS, READONLY, DEBUGGING
>   5 .comment      00000012  00000000  00000000  0000ca3e  2**0
>                   CONTENTS, READONLY
> SYMBOL TABLE:
> 00000000 l    df *ABS*  00000000 mallocfreespace.c
> 00000000 g     F .text  00000028 malloc_free_space
> 00000000         *UND*  00000000 RTEMS_Malloc_Heap
> 00000000         *UND*  00000000 rtems_region_get_information
> regards
> Matthew J Fletcher                      amimjf at connectfree.co.uk
> Software Engineering            Matthew.Fletcher at student.shu.ac.uk
> www.amimjf.org                  ICQ amimjf 44193496
> Since when did ignorance become a point of view ??
