Blown stack ?
Puro Markku
markku.puro at insta.fi
Fri Oct 5 15:06:51 UTC 2001
Hi,
On ev386ex BSP(~i386ex) I ran into problems that looks like
stack overrun. Anyhow I 'manage to fix' those by modifying
stack minimum size (original value was 1024) in
.../rtems-ss-20010816/c/src/exec/score/cpu/i386/rtems/score/cpu.h
( thats not the best place to do it but... ;)
--8<--------------------------------------------------------------
* Minimum size of a thread's stack.
#define CPU_STACK_MINIMUM_SIZE (4*1024)
Where can I define new value for (CPU_)STACK_MINIMUM_SIZE ?
Has anyone findout similar problems in startup ?
(pc386 works with default values. maybe its not a stack problem at all ? )
-Mp
examples-4.5.0:
termios with default stack=1024
Initialized console on port COM2 9600-8-N-1
*** TEST OF TERMIOS INPUT CAPABILITIES ***
You----------------------------------------------------------
Exception 13 caught at PC 33E4 by thread 134283265
Processor execution context at time of the fault was :
EAX = 1F EBX = 1F ECX = FD930 EDX = 3212
ESI = FB4B8 EDI = 361C EBP = FCCC8 ESP = FCC8C
Error code pushed by processor itself (if not 0) = C1C0
************ FAULTY THREAD WILL BE DELETED **************
after defining STACK_CHECKER_ON in
.../rtems-ss-20010816/c/src/lib/libbsp/i386/ev386ex/include/bsp.h
and CPU_STACK_MINIMUM_SIZE (2*1024) termios runs OK
but monitor generate BLOWN STACK.
*** MONITOR TASK TEST ***
Monitor ready, press enter to login.
BLOWN STACK!!! Offending task(0xfdb0c): id=0x08010007; name=0x524d4f4e
stack covers range 0x000f0d7c - 0x000f157b (2048 bytes)
after defining CPU_STACK_MINIMUM_SIZE (4*1024) 'monitor' runs OK
Markku Puro markku.puro at insta.fi Sarankulmankatu 20
tel. +358 3 2659 769 FIN-33900 Tampere
INSTRUMENTOINTI OY mobile +358 40 7092 769 http://www.insta.fi
C3i Systems fax +358 3 2659 501
