Code- and heap- size
Jan.Suchotzki at de.abb.com Jan.Suchotzki at de.abb.com
Mon Oct 8 07:33:17 UTC 2001
Hi,
that is very good. I already found the STACK_CHECKER, but not the function.
Thanks
Jan Suchotzki
 (Embedded     Eric Norum <eric.norum at usask.ca>@young.USask.Ca
 image moved   05.10.2001 18:44
 to file:
 pic31240.pcx)
Sent by:  Eric_Norum at young.USask.Ca
To:   Jan.Suchotzki at de.abb.com
cc:   rtems-users at oarcorp.com
Subject:  Re: Code- and heap- size
Security Level:?         Internal
Jan.Suchotzki at de.abb.com wrote:
> Hi,
> thank you, that is exactly what I was looking for.
> But it means, that I´m not able to get information about the
> memory used for local variables with functions like Heap_Get_information
> Jan Suchotzki
You can get information on per-task stack usage if you configure RTEMS
with the stack checking extension.
Just add
#define STACK_CHECKER_ON
in your configuration/initialization file somewhere before the
#include <confdefs.h>
line.
Then, in your program call Stack_check_Dump_usage() to print stack usage
statistics.
Eric Norum                                 eric.norum at usask.ca
Department of Electrical Engineering       Phone: (306) 966-5394
University of Saskatchewan                 FAX:   (306) 966-5407
Saskatoon, Canada.
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20011008/a25bdcc7/attachment-0001.obj>
