rtems 3c509 driver
Mon Oct 15 17:52:40 UTC 2001
Davide Del Vento wrote:
> Hi all again.
> I was trying to make my ethernet card 3c509 work. I was thinking that it
> should be a simple task, but it wasn't. I'm trying to make netdemos-4.5.0
> but I find some difficulties (compilation errors)
> I followed the suggestion of the second part of the
> http://www.oarcorp.com/rtems/maillistArchives/rtems-users/2001/may/msg00070.html
> and modify my /opt/rtems/pc486/lib/include/bsp.h (please note the path) as
> suggested, but when I run my netdemo.exe I get:
> RTEMS: DEC PCI network card not found !!
> I searched for 3c509.c in my /opt/rtems directory, but I didn't find
> anything (I find some stuff in my home where some sources are and I try to
> compile it, but I get lot of errors)
> Should I rebuild rtems, setting up everything for my platform?
I think your driver name is wrong in your network config because
the pc386 BSP defaults to the DEC one.  Try this:
Try this before your network configuration.
#undef RTEMS_BSP_NETWORK_DRIVER_NAME
#undef RTEMS_BSP_NETWORK_DRIVER_ATTACH
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "ep"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_3c509_driver_attach
> Thank you very much in advance,
> ;David
> _________________________________________________________________
> Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp
