rtems_event_receive and timeslicing
Brett Swimley
brett.swimley at aedinc.net
Tue Oct 23 15:49:47 UTC 2001
I have a situation where I have two tasks running at the same priority (=
128). Both tasks were created with RTEMS_PREEMPT and
RTEMS_TIMESLICE.
One task is blocked, waiting on an event that is sent by an ISR. The other
task is in an infinite loop as follows:
for ( ;; )
The task that is blocked on the rtems_event_receive() never appears to
receive the event. However, if I place an
rtems_task_suspend( RTEMS_SELF );
call prior to the infinite loop in the 2nd task - the first task does
receive the event.
I won't have this task construct in the near future as I implement more
functionality, but I would like to understand if the blocked task should run
under this situation with timeslicing enabled. If I am missing some
configuration options as well, I would like to know.
I have
#define CONFIGURE_TICKS_PER_TIMESLICE 50
in my Initialization function file.
I'm currently using the rtems-ss-20010816 snapshot.
Thanks for any insight.
Regards,
Brett Swimley
