bdm and multiprocessor machines
Erwin Rol
Erwin.Rol at Q-Soft-Engineering.com
Tue Oct 23 14:21:32 UTC 2001
What GCC version did you use ?
And did you (re)compile the module for SMP ?
- Erwin
Ulrich.Topp at de.abb.com wrote:
> Hello all,
> let me give my question to Pavel to you all, perhaps there is someone out,
> who solved already my problem.
> Would be fine, if we could get help ...
> Sincerly,
> Ulrich
> [my first mail to pavel pisa (pisa at cmp.felk.cvut.cz) ]
> Hello Pavel,
> we are using your bdm-driver for linux here very successful and indeed, it
> makes it possible to develop SW for our m68332-board.
> But now we got a wonderful new PC with two CPUs.
> We have SuSE-Linux 7.2 installed with kernel 2.4, BUT now your driver
> doesn't work any longer.
> We compiled it, and it is loadable ('insmod-able') but if we try to
> download our application, it crashes.
> Is it a known problem and do you have some hints/patches/workarounds
> already?
> It would be great to hear from you,
> Ulrich Topp
> PS: This is what the log-file says:
> bdmlib_load: program name o-optimize/pecosdemo.nxe
> bdmlib_set_sys_reg error: reg 0xf cont 0x5 error 617
> bdmlib_set_sys_reg error: reg 0xe cont 0x5 error 617
> PPS: And this is what the system-messages are:
> Oct 18 16:49:13 linux kernel: BDM init_module
> Oct 18 16:49:13 linux kernel: $RCSfile: bdm.c,v $
> Oct 18 16:49:13 linux kernel: $Revision: 2.13 $
> Oct 18 16:49:13 linux kernel: $Date: 1998/11/19 13:15:56 $
> Oct 18 16:49:13 linux kernel: Version PD ICD +ISP
> Oct 18 16:49:13 linux kernel: Compiled at Oct 1 2001 14:55:49
> Oct 18 16:49:13 linux kernel: BDM driver succesfully registered !!
> Oct 18 16:58:23 linux kernel: bdm_ioctl minor=0 cmd=11 (BDM_SENSECABLE)
> arg=0x0
> Oct 18 16:58:23 linux kernel: bdm_ioctl: setting bdm_sense to 0
> Oct 18 16:58:36 linux kernel: bdm_ioctl minor=0 cmd=6 (BDM_GET_STATUS)
> arg=0x0
> Oct 18 16:58:36 linux kernel: bdm_pd_getstatus minor=0 res=0x18
> Oct 18 16:58:36 linux kernel: bdm_write minor 0 len 6
> Oct 18 16:58:36 linux kernel: bdm_pd_ser_clk: writing 248f
> Oct 18 16:58:36 linux kernel: bdm_pd_ser_clk: read 1ffff bits 0
> Oct 18 16:58:36 linux kernel: bdm_write sent: 248f received: 1ffff
> Oct 18 16:58:36 linux kernel: bdm_pd_ser_clk: writing 0
> Oct 18 16:58:36 linux kernel: bdm_write sent: 0 received: 1ffff
> Oct 18 16:58:36 linux kernel: bdm_pd_ser_clk: writing 248e
> Oct 18 16:58:36 linux kernel: bdm_write sent: 248e received: 1ffff
> [pavels answer]
> Hello Ulrich,
> I would like to have your problems with SMP machine ;-)
> I cannot test driver on the SMP box. (We have some SMP Linuxes
> at University, but these machines are used as servers and vision
> workstation and I have no right to test my kernel stuff on them).
> I have some experience with multi-open and parallel access
> drivers (uLan, DMSDOS), but I left BDM driver as simple as possible
> => only single open (there is no need for multiple GDB to one CPU)
> and only blocking calls => I think, that SMP is no problem for BDM.
> Speed could be bigger one, but ISA in/out frequency is constant
> for long time now.
> I see other problem. You have no response from target (1ffff).
> There could be two reasons.
> - Weak PC parallel port hardware
> or target wiring problem.
> - BPP parallel port was not handled in my older patches
> Change was so small that I have not renamed archive,
> but I have updated it about three weeks ago.
> I hope, that it solves your problem. I am sending last driver
> source as well.
> Best wishes
> Pavel Pisa
> e-mail: pisa at cmp.felk.cvut.cz
> www: http://cmp.felk.cvut.cz/~pisa
> work: http://www.pikron.com
> [my reply]
> Hello Pavel,
> thanks for your answer.
> We checked the cable as well as the parallel port of the PC. Under Linux a
> HP printer was perfectly running and the cable is in perfect use from
> another PC.
> What do you mean with 'BPP' (Is it a typo for 'EPP' ?)
> >From when are the newest sources of the driver? (I found on your server a
> version from 09-Okt-01)
> Sincerly,
> Ulrich
