FYI - updated printk()
Hennenfent, Nick {AVL~Roswell}
NICK.HENNENFENT at ROCHE.COM
Wed Oct 24 16:21:46 UTC 2001
All,
For anyone that needs it - like me - I have added a binary format to
printk()
I use it like this -
printk(" %08B \n", 0xAA ); prints 10101010
printk(" %016B \n", 0x5555 ); prints 0101010101010101
printk(" %032B \n", 0x12345678 ); prints
00010011011101000101011001111000
The 0 after the % is used as the leading fill character and the 8/16/32 is
used
as the output field width just like with other numbers.
Regards,
Nick
| printk.c v1.1 - PC386 BSP - 1997/08/07
| (C) Copyright 1997 -
| - NavIST Group - Real-Time Distributed Systems and Industrial Automation
| http://pandora.ist.utl.pt
| Instituto Superior Tecnico * Lisboa * PORTUGAL
| Disclaimer:
| This file is provided "AS IS" without warranty of any kind, either
| expressed or implied.
| This code is based on code by: Jose Rufino - IST
| $Id: printk.c,v 1.2 2001/10/10 00:35:06 hennenfen Exp $
#if HAVE_CONFIG_H
#include "config.h"
#endif
#include <stdarg.h>
#include <bspIo.h>
/* #include <libcpu/cpu.h> */
| Function: printNum
| Description: print number in a given base.
| Global Variables: None.
| Arguments: num - number to print, base - base used to print the
number.
| Returns: Nothing.
static void
printNum(long unsigned int num, int base, int sign, int maxwidth, int lead)
long unsigned int n;
int count;
char toPrint[64];
if ( (sign == 1) && ((long)num < 0) ) {
BSP_output_char('-');
num = -num;
if (maxwidth) maxwidth--;
count = 0;
while ((n = num / base) > 0) {
toPrint[count++] = (num - (n*base));
num = n ;
toPrint[count++] = num;
if (maxwidth && count < maxwidth) {
for (n=maxwidth-count ; n ; n-- )
BSP_output_char(lead);
for (n = 0; n < count; n++){
BSP_output_char("0123456789ABCDEF"[(int)(toPrint[count-(n+1)])]);
} /* printNum */
| Function: printk
| Description: a simplified version of printf intended for use when the
console is not yet initialized or in ISR's.
| Arguments: as in printf: fmt - format string, ... - unnamed
arguments.
| Returns: Nothing.
void
printk(char *fmt, ...)
va_list ap; /* points to each unnamed argument in turn */
char c, *str;
int lflag, base, sign, width, lead;
/* unsigned int level; */
/* _CPU_ISR_Disable(level); */
va_start(ap, fmt); /* make ap point to 1st unnamed arg */
for (; *fmt != '\0'; fmt++)
lflag = 0;
base = 0;
sign = 0;
width = 0;
lead = ' ';
if (*fmt == '%')
fmt++;
if (*fmt == '0' ) {
lead = '0';
fmt++;
while (*fmt >= '0' && *fmt <= '9' ) {
width *= 10;
width += (*fmt - '0');
fmt++;
if ((c = *fmt) == 'l')
lflag = 1;
c = *++fmt;
switch (c)
case 'b': case 'B': base = 2; sign = 0; break;
case 'o': case 'O': base = 8; sign = 0; break;
case 'd': case 'D': base = 10; sign = 1; break;
case 'u': case 'U': base = 10; sign = 0; break;
case 'x': case 'X': base = 16; sign = 0; break;
case 's':
for (str = va_arg(ap, char *); *str; str++)
BSP_output_char(*str);
break;
case 'c':
#if 0
#if defined(_TMS320C3x) || defined(_TMS320C4x)
BSP_output_char(va_arg(ap, int));
#else
BSP_output_char(va_arg(ap, char));
#endif
#else
#endif
break;
default:
BSP_output_char(c);
break;
} /* switch*/
if (base)
printNum(lflag ? va_arg(ap, long int) : (long int)va_arg(ap, int),
base, sign, width, lead);
else
BSP_output_char(*fmt);
va_end(ap); /* clean up when done */
/* _CPU_ISR_Enable(level); */
} /* printk */
URL: <http://lists.rtems.org/pipermail/users/attachments/20011024/29263408/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20011024/29263408/attachment.obj>
