Installing multiple toolset versions
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Tue Oct 30 14:50:07 UTC 2001
Hi,
currently I need to work with two distinct toolset versions
(gcc/binutil/newlib), since I am sharing my time between two
projects based on different RTEMS versions (One is the
PPC403/405 software splitup :-> )
Up to now I have downloaded the "ready to run" RPMs for the
toolsets but in my current situation I ran into problems,
because at least the GCC package (powerpc-rtems-gcc-
gcc2.95.3newlib1.9.0-1.i386.rpm) only works when installed in
the default location (/opt/rtems/...), so there can only be
one compiler package installed for a certain target
architecture. Currently I use a different machine to install
and run the second toolset, but this is not very nice...
Some years ago, when RPMs where not available, the tools per
default were installed in a dedicated directory with a unique
name like /usr/local/rtems/<gcc-version>-<binutil-version>-
<newlib-version>. Wouldn't it be a good idea to fall back to
such a naming scheme for future toolset RPMs? Then it would be
possible to have multiple versions of a toolset installed on
the same machine and multi-project maintenance would be much
easier...
Any further opinions on that?
Bye,
Thomas.
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-
systems.de/pgp_key.htm
