Code- and heap- size
Eric Norum
eric.norum at usask.ca
Fri Oct 5 16:44:22 UTC 2001
Jan.Suchotzki at de.abb.com wrote:
> Hi,
> thank you, that is exactly what I was looking for.
> But it means, that I´m not able to get information about the
> memory used for local variables with functions like Heap_Get_information()?
> Jan Suchotzki
You can get information on per-task stack usage if you configure RTEMS
with the stack checking extension.
Just add
#define STACK_CHECKER_ON
in your configuration/initialization file somewhere before the
#include <confdefs.h>
line.
Then, in your program call Stack_check_Dump_usage() to print stack usage
statistics.
Eric Norum eric.norum at usask.ca
Department of Electrical Engineering Phone: (306) 966-5394
University of Saskatchewan FAX: (306) 966-5407
Saskatoon, Canada.
