FW: MIPS BSPs
    Wayne Bullaughey
    wayne at wmi.com
    Mon Oct 15 19:02:33 UTC 2001
> -----Original Message-----
> From: joel at wmi.com [mailto:joel at wmi.com]On Behalf Of Joel Sherrill
> Sent: Monday, October 15, 2001 1:49 PM
Something about the email headers you send get translated by our mail server
to be from a joel here at WMI.
> Because the ultimate goal is to be able to provide a prebuilt
> RTEMS (ala libc.a) that is augmented by a BSP Kit to be specific
> to your hardware.  At that point, libcpu and libbsp will be
> foundation of the BSP Kit the main things a user builds locally.
> Everything else will have been prebuilt.
I hadn't understood what you meant by this before. I now see the problem
in the solution I was suggesting.
> There is a documented classification now "RTEMS_CPU_MODEL" which is
> used in the libcpu code to distinguish which set of code to use
> to augment the basic CPU port. libcpu already includes cache
> management and interrupt vectoring code for the mips.
Where is this documented?
> The ISA is not completely hidden because there are issues of
> branch delay, register sizes (to save/restore), FPU presence/abscence,
> etc. This covers most of the code in score/cpu.  Interrupt dispatching
> and cache management tend to be CPU model dependent so we have
> that in libcpu.
I don't think FPU presence can be determined from ISA. There probably should
be a function that returns TRUE if it exists. libcpu would supply the
function or maybe libbsp.
Wayne Bullaughey               Voice:  (610) 692-9526 ext: 104
Woodward McCoach, Inc.                 (877) 284-4804
1180 McDermott Drive           Fax:    (610) 436-8258
West Chester, PA 19380         Email:  wayne at wmi.com
                               web:    www.wmi.com
