powerpc-rtems-gcc-gcc2.95.2newlib1.8.2-7.i386.rpm corrupt?
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Oct 26 18:49:09 UTC 2001
David Hamilton wrote:
> I just downloaded the precompiled toolsets from the release directory for
> linux x86 host, powerpc target.
> The first three rpm files were ok, but running
> rpm -i powerpc-rtems-gcc-gcc2.95.2newlib1.8.2-7.i386.rpm
> produced
> error:unpacking of archive failed ..... MD5 sum mismatch.
> I repeated the download, but got the same error!
> Next, I downloaded from elsewhere on the ftp site, a similar rpm file but
> with newlib1.8.2-8 and this package installed ok.
> It seems that the file mentioned above really is corrupt!!?
Did you ftp in ASCII mode? The file seems to be ok on this side
I checked the file in
/pub/rtems/releases/4.5.0/c_tools/linux_x86/RPMS/powerpc-rtems
with this command:
rpm2cpio powerpc-rtems-gcc-gcc2.95.2newlib1.8.2-7.i386.rpm | cpio -itv
and then proceeded to install them on the OAR ftp server directly
from the download directory:
[root at usa powerpc-rtems]# rpm -i
../shared/rtems-base-binutils-2.9.5.0.24-1.i386.rpm
powerpc-rtems-binutils-2.9.5.0.24-1.i386.rpm
../shared/rtems-base-gcc-gcc2.95.2newlib1.8.2-7.i386.rpm
[root at usa powerpc-rtems]# rpm -q -g rtems
> David
joel at OARcorp.com On-Line Applications Research
