about getcwd
Tu Juan
jtu at utstar.com
Wed Sep 5 22:27:39 UTC 2001
Anyone who can help me to explain these problems in getcwd().
* If it's a mount point, have to stat each element because
* the inode number in the directory is for the entry in the
* parent directory, not the inode number of the mounted file.
save_errno = 0;
if (s.st_dev == dev)// When use this, it's not work.
for (;;)
if (!(dp = _readdir (dir)))
goto notfound;
if (dp->d_ino == ino) // dp->d_ino is always be 1. It has been set in imfs_dir_read (imfs_directory.c).
break;
else // This is work.
for (;;)
goto notfound;
if (ISDOT (dp))
continue;
bcopy (dp->d_name, bup, strlen (dp->d_name) + 1);
/* Save the first error for later. */
if (stat (up, &s))
if (!save_errno)
save_errno = errno;
errno = 0;
continue;
if (s.st_dev == dev && s.st_ino == ino)
break;
Thanks,
Tu Juan
URL: <http://lists.rtems.org/pipermail/users/attachments/20010905/00dbb3db/attachment.html>
