Wed Sep 19 11:19:14 UTC 2001
> Mike Liu wrote:
> Hi all
> I am a new comer of rtems.
> I had build rtems successfully on linux, but I can't build it on
> cygwin.
> I installed the cygwin 2.29 and the rtems cygwin tools,
> when I try to config the rtems-4.5.0, error has occured:
> I wander if there is anyone had build rtems successfully under
> cygwin??
Yes if you know a handful of things that can go wrong under Cygwin.
It isn't perfect.
There was a recent post with very explicit details about Cygwin.
The archives have not been rerun in the last few days.  I will
make sure they get updated when I get in to the office.
The 1st big trick is to make sure cc.exe is linked to gcc.exe.
This post from March 2001 details one common and confusing problem.
http://www.oarcorp.com/rtems/maillistArchives/rtems-users/2001/march/msg00178.html
> mike
