RTEMS IDE?
Kiran C kiranc at tataelxsi.co.in
Thu Sep 6 15:54:47 UTC 2001
Hi,
       Is any body using any IDE for RTEMS?
       What I mean is some of the IDE's are customizable,so that you can
specify the build tools et al..
        Well I have a suggestion to make..
        If you are using Cygwin as a developmental environment,then editplus
is a really good editor.
        http://www.editplus.com
        Here u can configure tools in the tools menu,That is Create Menu
Items like Compile,Clean,Run,Debug et al.
        Gives u a feel of an IDE.
        Also editplus takes you to the corresponding file when clicking on
the capured compiler output on its outout window.
         But Edit Plus is a Shareware..I would like to know if there are any
free editor like that...
 Bye,
Kiran
