more gnat/rtems ACATS results
Wed Sep 12 17:12:54 UTC 2001
In rev'ing the RPMs to add more CPUs, I got more
ACATS results. :)
SPARC/erc32
acats4gnat results cz 3 /       4
acats4gnat results a 63 /      75
acats4gnat results c2 35 /      35
acats4gnat results c3 329 /     349
acats4gnat results c4 323 /     338
acats4gnat results c5 93 /      95
acats4gnat results c6 78 /      81
acats4gnat results c7 44 /      50
acats4gnat results c8 118 /     140
acats4gnat results c9 38 /     255
acats4gnat results ca 73 /      74
acats4gnat results cb 36 /      43
acats4gnat results cc 106 /     117
acats4gnat results cd 162 /     172
acats4gnat results ce 262 /     268
acats4gnat results cxa 80 /      85
acats4gnat results cxb 29 /      30
acats4gnat results cxc 7 /      16
acats4gnat results cxd 6 /      39
acats4gnat results cxe 1 /       1
acats4gnat results cxf 19 /      20
acats4gnat results cxg 26 /      29
acats4gnat results cxh 4 /       4
acats4gnat results d 4 /       4
acats4gnat results e 11 /      11
acats4gnat results l 25 /      26
This compares pretty favorably with the PowerPC/psim
reported earlier:
acats4gnat results a 75 /      75
acats4gnat results c3 347 /     349
acats4gnat results c4 333 /     338
acats4gnat results c5 95 /      95
acats4gnat results c6 81 /      81
acats4gnat results c7 47 /      50
acats4gnat results c8 140 /     140
acats4gnat results c9 246 /     255
acats4gnat results cb 43 /      43
acats4gnat results cc 117 /     117
acats4gnat results cd 172 /     172
acats4gnat results cxa 85 /      85
acats4gnat results cxc 9 /      16
acats4gnat results cxd 27 /      39
acats4gnat results cxf 20 /      20
acats4gnat results cxg 28 /      29
acats4gnat results l 26 /      26
More than one sparc test fails to link because the
sparc trampoline code references mprotect() and
getpagesize() which don't exist on RTEMS.  There
appear to be able 350 undefined reference errors
for mprotect() in the run log which correlates
with the failures nicely. :)
FWIW I had the following error trying to build
i386-rtemscoff RPMs.  Any ideas?
opt/usr_src_redhat_BUILD/i386-rtemscoff-gnat-newlib/build/gcc/xgcc
-B/opt/usr_src_redhat_BUILD/i386-rtemscoff-gnat-newlib/build/gcc/
-DCROSS_COMPILE -DIN_GCC    -O2 -I./include  libgcc1-test.o -o
libgcc1-test \
  -nostartfiles -nostdlib
`/opt/usr_src_redhat_BUILD/i386-rtemscoff-gnat-newlib/build/gcc/xgcc
--print-libgcc-file-name`
/opt/usr_src_redhat_BUILD/i386-rtemscoff-gnat-newlib/build/gcc/libgcc.a:
could not read symbols: Archive has no index; run ranlib to add one
make[1]: *** [libgcc1-test] Error 1
make[1]: Leaving directory
`/opt/usr_src_redhat_BUILD/i386-rtemscoff-gnat-newlib/build/gcc'
